#302581 - 27/09/2007 12:11 No Hard Disk Found
brax
Loc: Birmingham, AL
Ok this morning I got the dreaded NO Hard Disk Found. A little history on the player. I bought the player off ebay less then a year ago. I upgraded to v3.01 and Hijack. I recently had started getting some fault errors and would every now and then get a No Hard Disk Found. A simple reboot would clear the problem. However this morning it does not seem to be going away. Last night the player took a little fall, about a foot off the bar on to the counter, but landed hard on it's side. This morning was the first time to power it up since the fall. I tried to do an "upgrade" and put v2.01 back on but that failed. I was able to put Hijack back on though through the logo editor. I can hear the drive spinning.
Before I opended it up I wanted to get your guys input on what to look for first, second, third, etc...
Bot log after putting Hijack back on.
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v477 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Fri Jul 13 14:42:45 EDT 2007
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 30102880) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (988k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is ffffffff 'ÿÿÿÿ'
Tuner: loopback=0, ID=-1
show_message("Hijack v477 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005800).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0xff84
ide_data_test: wrote 0xffff read 0xff84
ide_data_test: wrote 0xaaaa read 0xaa80
ide_data_test: wrote 0x5555 read 0x5584
ide_data_test: wrote 0x0000 read 0x1000
ide_data_test: wrote 0xffff read 0xffff
ide_data_test: wrote 0xaaaa read 0xaaaa
ide_data_test: wrote 0x5555 read 0x5555
ide_data_test: wrote 0x0000 read 0xffff
ide_data_test: wrote 0x0000 read 0x3000
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0b:40
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump... VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
#302582 - 27/09/2007 12:24 Re: No Hard Disk Found [Re: brax]
Last night the player took a little fall, about a foot off the bar on to the counter, but landed hard on it's side. [...] Before I opended it up I wanted to get your guys input on what to look for first, second, third, etc...
The classic ones are (a) shock has pulled IDE cable off drive or motherboard pinheader (plug it back in), and/or (b) shock has pulled motherboard IDE pinheader off its solder joints (resoldering job, consult a skilled repairer). It turns out that some units are unusually susceptible to failure mode (b) as not enough solder was used on those connectors when they were originally made.
#302583 - 27/09/2007 12:50 Re: No Hard Disk Found [Re: peter]
brax
Loc: Birmingham, AL
Thanks! Well I kind of got a little curious so I opened it up. I disconnected the IDE cable at both the hard drive and mother board. Powered it back up and it booted up. I inspected the IDE header on the mother board and it looked ok, looked like a few of the pins could use a little more solder, but did not see anything obvious. Anyway since it seems to be booting up as of now I am going to wait and see if the problem comes back. If it does I will touch up the IDE header pins.
So looks like for now my player is back up and running.
#302584 - 28/09/2007 10:23 Re: No Hard Disk Found [Re: brax]
simspos
Loc: Dudley, UK
You might also want to look at the crimping of the connectors on the IDE cable itself as this has been known to cause intermittent problems.
Cheers, Sim
#302585 - 28/09/2007 16:46 Re: No Hard Disk Found [Re: simspos]
brax
Loc: Birmingham, AL
Yea I am planning on getting a light kit for my buttons at some point from Eutronix, will probably be Christmas present from the wife. I will order a couple of extra IDE cables then also as the more I read the more the problem sounds like the IDE header and/or cable.
Having to touch up a couple solder joints or replacing the cable is nothing. I am just glad it is not something major.
#302586 - 28/09/2007 21:53 Re: No Hard Disk Found [Re: brax]
Just be sure you do it properly!
