#314516 - 28/09/2008 21:53 Huawei USB 3G data card
I've got a Huawei E870 ExpressCard which is actually just one of their regular USB data cards but in ExpressCard shape. It is supported under Windows and OSX officially but apparently you can make it work under Linux as well. It doesn't require firmware to make it work. You just need to send it the correct command to switch from MSC only mode.
The annoying part is that its a composite USB device. You plug it in and it will appear as a USB flash drive in one mode. The software and drivers you need to operate it are on there so you don't normally need a CD. Once you have the software and drivers installed, it will appear as 2 serial ports and the previously mentioned flash drive.
The issue is if you want to try and uninstall the software that gets installed. It will let you do it but then you're stuck because it'll refuse to enumerate the USB flash drive again. I had to actually do a system restore to get it working again.
Bit of a long shot but anybody know how to uninstall properly?
On a side note, I'm using the mobile broadband service from Vodafone for when I'm out and about. The latency is high during the day but apart from that it is okay. £15 a month for 3GB a month and the modem was free. 3GB is enough for what I need to do when not near WiFi.
#314521 - 29/09/2008 00:45 Re: Huawei USB 3G data card [Re: tman]
You did try uninstalling it in the Device Manager?
#314522 - 29/09/2008 01:00 Re: Huawei USB 3G data card [Re: gbeer]
It just disappears from Device Manager once you uninstall the runtime that gets installed. I'm guessing that the driver needs some component of the runtime and it dies without it. Windows just makes the inserted card noise and then the error noise straight away. The event logs don't have anything at all which is odd.
#314524 - 29/09/2008 01:20 Re: Huawei USB 3G data card [Re: tman]
The basic event logs fail to record many many things. Once upon a time, I stumbled onto a way to configure what gets monitored. What I remember was typing in some obscure command into the Run dialog.
Also in the device manager there is a Action to "scan for hardware changes" that recovers devices that were uninstalled.
