#314663 - 04/10/2008 12:13 Problems with Firefox - OSX
petteri
Loc: Helsinki, Finland
For the past few weeks I've been getting a strange problem with Firefox (ver. 3.0.3) running under OSX. Every now and then the browser starts rendering screens all garbled. The browser continues to function, and I can usually keep using it. The garbled page can sometimes be display correctly is I hit refresh, sometimes not. Another thing that happens is that I cannot "quit" out of the program, I must use force quit. Here are some screen shots:
Any ideas on what is causing this? It seems to happen a lot on Facebook, or after I visit Facebook.
#314664 - 04/10/2008 13:56 Re: Problems with Firefox - OSX [Re: petteri]
That's odd. It's like you've zoomed the text, except that can't be what's happening because it's only for some of the elements. And some of the images have been replaced with their text equivalents, but again, only for some of the elements. It's like the machine thinks you're in "Accessibility" mode, but only half way.
#314666 - 04/10/2008 15:51 Re: Problems with Firefox - OSX [Re: petteri]
It looks like for some reason that it's unable to load certain elements. The first appears like it was simply unable to load a few images. The second looks like it was also unable to load some stylesheets.
My guess would be that Firefox is unable to open network connections on occasion. The two things that come to mind that might be causing that are firewall/router limits and OS limits.
Honestly, I feel like OS limits are more likely. When you see this happen, try this: Open a Terminal and find Firefox's process id:
% ps ax | grep -i firefox
13120   ??  Ss   253:53.47 /Applications/Firefox.app/Contents/MacOS/firefox-bin -foreground
16336 s000  R+     0:00.00 grep -i firefox
That shows that Firefox's process id is 13120. Now see how many filehandles it has open:
% /usr/sbin/lsof -p 13120
COMMAND     PID   USER   FD   TYPE    DEVICE  SIZE/OFF     NODE NAME
firefox-b 13120 wfaulk  cwd    DIR      14,2      1632  3269319 /Applications/Firefox.app/Contents/MacOS
firefox-b 13120 wfaulk  txt    REG      14,2     34220  7858208 /Applications/Firefox.app/Contents/MacOS/firefox-bin
firefox-b 13120 wfaulk   97r   REG      14,2      8599  3527761 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 13120 wfaulk   98r   REG      14,2       286  3527759 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
Count the number of rows that have a number in the fourth column, regardless of a trailing letter. If it's close to an even binary number (that is, 128, 256, 512, 1024), process limits might be the problem.
Does it only happen after Firefox has been open a while? It might be leaking file descriptors for some reason, probably due to an extension.
That's enough to try initially, I guess. Get back to us.
#314677 - 04/10/2008 23:23 Re: Problems with Firefox - OSX [Re: wfaulk]
petteri
Ok, I've been messing around with Firefox all afternoon and into the evening, and of course everything is fine! I'll report back again on Monday, as tomorrow I'll be too busy to muck about with the computer.
#314707 - 06/10/2008 10:37 Re: Problems with Firefox - OSX [Re: petteri]
petteri
Here's the dump:
firefox-b 25822 macbook cwd DIR 14,2 1394 2 /
firefox-b 25822 macbook txt REG 14,2 43584 30942792 /Applications/Firefox.app/Contents/MacOS/firefox-bin
firefox-b 25822 macbook txt REG 14,2 38716 30942055 /Applications/Firefox.app/Contents/MacOS/libxpcom.dylib
firefox-b 25822 macbook txt REG 14,2 105576 30942041 /Applications/Firefox.app/Contents/MacOS/libplds4.dylib
firefox-b 25822 macbook txt REG 14,2 115384 30942039 /Applications/Firefox.app/Contents/MacOS/libplc4.dylib
firefox-b 25822 macbook txt REG 14,2 479500 30942029 /Applications/Firefox.app/Contents/MacOS/libnspr4.dylib
firefox-b 25822 macbook txt REG 14,2 307428 30942043 /Applications/Firefox.app/Contents/MacOS/libsmime3.dylib
firefox-b 25822 macbook txt REG 14,2 1319716 30942027 /Applications/Firefox.app/Contents/MacOS/libmozjs.dylib
firefox-b 25822 macbook txt REG 14,2 801152 30942049 /Applications/Firefox.app/Contents/MacOS/libsqlite3.dylib
firefox-b 25822 macbook txt REG 14,2 435696 30942051 /Applications/Firefox.app/Contents/MacOS/libssl3.dylib
firefox-b 25822 macbook txt REG 14,2 2113056 30942031 /Applications/Firefox.app/Contents/MacOS/libnss3.dylib
firefox-b 25822 macbook txt REG 14,2 190748 30942037 /Applications/Firefox.app/Contents/MacOS/libnssutil3.dylib
firefox-b 25822 macbook txt REG 14,2 443048 30942047 /Applications/Firefox.app/Contents/MacOS/libsoftokn3.dylib
firefox-b 25822 macbook txt REG 14,2 1200 1263195 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/Resources/QD.rsrc
firefox-b 25822 macbook txt REG 14,2 58916 30941747 /Applications/Firefox.app/Contents/MacOS/components/libbrowserdirprovider.dylib
firefox-b 25822 macbook txt REG 14,2 15555520 1767395 /private/var/folders/L-/L-YDEdJVEu0hwx+R7+-Xh++++TI/-Caches-/com.apple.ATS/annex_aux
firefox-b 25822 macbook txt REG 14,2 2295501 1257768 /System/Library/Fonts/LucidaGrande.dfont
firefox-b 25822 macbook txt REG 14,2 134936 30941743 /Applications/Firefox.app/Contents/MacOS/components/libalerts_s.dylib
firefox-b 25822 macbook txt REG 14,2 314128 1254327 /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
firefox-b 25822 macbook txt REG 14,2 808008 2524450 /System/Library/Keyboard Layouts/AppleKeyboardLayouts.bundle/Contents/Resources/AppleKeyboardLayouts-L.dat
firefox-b 25822 macbook txt REG 14,2 97968 30027178 /System/Library/Caches/com.apple.IntlDataCache.le.kbdx
firefox-b 25822 macbook txt REG 14,2 311236 30942035 /Applications/Firefox.app/Contents/MacOS/libnssdbm3.dylib
firefox-b 25822 macbook txt REG 14,2 794600 30942025 /Applications/Firefox.app/Contents/MacOS/libfreebl3.dylib
firefox-b 25822 macbook txt REG 14,2 26962324 30941557 /Applications/Firefox.app/Contents/MacOS/XUL
firefox-b 25822 macbook txt REG 14,2 627708 30942033 /Applications/Firefox.app/Contents/MacOS/libnssckbi.dylib
firefox-b 25822 macbook txt REG 14,2 144580 1258416 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/Resources/HIToolbox.rsrc
firefox-b 25822 macbook txt REG 14,2 47800 26114311 /Library/InputManagers/Saft/SaftLoader.bundle/Contents/MacOS/SaftLoader
firefox-b 25822 macbook txt REG 14,2 460121 2523310 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook txt REG 14,2 148736 1254470 /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
firefox-b 25822 macbook txt REG 14,2 10235872 30026582 /usr/share/icu/icudt36l.dat
firefox-b 25822 macbook txt REG 14,2 123056 30022913 /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
firefox-b 25822 macbook txt REG 14,2 367168 1254330 /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
firefox-b 25822 macbook txt REG 14,2 56160 29205148 /System/Library/Frameworks/QuickTime.framework/Versions/A/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook txt REG 14,2 905872 1274746 /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
firefox-b 25822 macbook txt REG 14,2 141376 29205150 /System/Library/Frameworks/QuickTime.framework/Versions/A/Resources/QuickTime.rsrc
firefox-b 25822 macbook txt REG 14,2 542927 535785 /Users/macbook/Library/Fonts/Trebuchet MS/..namedfork/rsrc
firefox-b 25822 macbook txt REG 14,2 2011136 30182699 /Library/Caches/com.apple.LaunchServices-023501.csstore
firefox-b 25822 macbook txt REG 14,2 553284 1276898 /Library/Fonts/Arial Italic.ttf
firefox-b 25822 macbook txt REG 14,2 1038477 535716 /Users/macbook/Library/Fonts/Arial/..namedfork/rsrc
firefox-b 25822 macbook txt REG 14,2 615690 535786 /Users/macbook/Library/Fonts/Verdana/..namedfork/rsrc
firefox-b 25822 macbook txt REG 14,2 5425538 1258409 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/Resources/Extras2.rsrc
firefox-b 25822 macbook txt REG 14,2 19336 1767746 /private/var/folders/L-/L-YDEdJVEu0hwx+R7+-Xh++++TI/-Caches-/com.apple.IntlDataCache.le.sbdl
firefox-b 25822 macbook txt REG 14,2 18532 1766630 /System/Library/Caches/com.apple.IntlDataCache.le.tecx
firefox-b 25822 macbook txt REG 14,2 106000 1305020 /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
firefox-b 25822 macbook txt REG 14,2 372620 30941745 /Applications/Firefox.app/Contents/MacOS/components/libbrowsercomps.dylib
firefox-b 25822 macbook txt REG 14,2 1832384 2522590 /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/Resources/SArtFile.bin
firefox-b 25822 macbook txt REG 14,2 4804592 6355944 /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
firefox-b 25822 macbook txt REG 14,2 5836820 1255095 /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/Resources/ArtFile.bin
firefox-b 25822 macbook txt REG 14,2 1763409 1257772 /System/Library/Fonts/Times.dfont
firefox-b 25822 macbook txt REG 14,2 11565328 3771003 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/MacOS/Flash Player
firefox-b 25822 macbook txt REG 14,2 3629894 1279473 /Library/Fonts/Osaka.dfont
firefox-b 25822 macbook txt REG 14,2 6392812 535770 /Users/macbook/Library/Fonts/MS PGothic.ttf
firefox-b 25822 macbook txt REG 14,2 2402112 1257764 /System/Library/Fonts/Helvetica.dfont
firefox-b 25822 macbook txt REG 14,2 4199824 2522522 /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
firefox-b 25822 macbook txt REG 14,2 1059776 2534333 /usr/lib/dyld
firefox-b 25822 macbook txt REG 14,2 133246976 30027124 /private/var/db/dyld/dyld_shared_cache_i386
firefox-b 25822 macbook txt REG 14,2 450560 1254322 /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
firefox-b 25822 macbook txt REG 14,2 614080 1254323 /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
firefox-b 25822 macbook 0r CHR 3,2 0t0 66054404 /dev/null
firefox-b 25822 macbook 1 PIPE 0x3fb4064 16384
firefox-b 25822 macbook 2 PIPE 0x3fb4064 16384
firefox-b 25822 macbook 3w REG 14,2 0 535299 /Users/macbook/Library/Application Support/Firefox/Profiles/33yydxv8.default/.parentlock
firefox-b 25822 macbook 4 PIPE 0x3fb44b0 16384
firefox-b 25822 macbook 5 PIPE 0x79c29cc 16384
firefox-b 25822 macbook 7r REG 14,2 5425538 1258409 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/Resources/Extras2.rsrc
firefox-b 25822 macbook 8r REG 14,2 989880 4105718 /Users/macbook/Library/Application Support/Firefox/Profiles/33yydxv8.default/extensions/{d10d0bf8-f5b5-c8b4-a8b2-2b9879e08c5d}/chrome/adblockplus.jar
firefox-b 25822 macbook 9r REG 14,2 1915550 30941591 /Applications/Firefox.app/Contents/MacOS/chrome/toolkit.jar
firefox-b 25822 macbook 10r REG 14,2 1044802 4309930 /Users/macbook/Library/Application Support/Firefox/Profiles/33yydxv8.default/extensions/{069FB356-C69F-7349-D092-AB28AF836D0E}/chrome/chrome.jar
firefox-b 25822 macbook 11u REG 14,2 2048 4025030 /Users/macbook/Library/Application Support/Firefox/Profiles/33yydxv8.default/permissions.sqlite
firefox-b 25822 macbook 12r REG 14,2 1067337 31152777 /Users/macbook/Library/Caches/Firefox/Profiles/33yydxv8.default/XUL.mfasl
firefox-b 25822 macbook 13r REG 14,2 1944172 30941567 /Applications/Firefox.app/Contents/MacOS/chrome/browser.jar
firefox-b 25822 macbook 14r REG 14,2 468013 30941579 /Applications/Firefox.app/Contents/MacOS/chrome/en-US.jar
firefox-b 25822 macbook 15 PIPE 0x79c17d4 16384
firefox-b 25822 macbook 16 PIPE 0x79c2c24 16384
firefox-b 25822 macbook 17u REG 14,2 147456 535330 /Users/macbook/Library/Application Support/Firefox/Profiles/33yydxv8.default/cert8.db
firefox-b 25822 macbook 18u REG 14,2 16384 535331 /Users/macbook/Library/Application Support/Firefox/Profiles/33yydxv8.default/key3.db
firefox-b 25822 macbook 19u REG 14,2 172032 4025077 /Users/macbook/Library/Application Support/Firefox/Profiles/33yydxv8.default/places.sqlite
firefox-b 25822 macbook 20r REG 14,2 792 30942329 /Applications/Firefox.app/Contents/Resources/firefox-bin.rsrc
firefox-b 25822 macbook 21r REG 14,2 144580 1258416 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/Resources/HIToolbox.rsrc
firefox-b 25822 macbook 22r REG 14,2 460121 2523310 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 23r REG 14,2 26105 29211891 /Users/macbook/Library/Application Support/Firefox/Profiles/33yydxv8.default/extensions/{0545b830-f0aa-4d7e-8820-50a4629a56fe}/chrome/clrtabs.jar
firefox-b 25822 macbook 24u REG 14,2 8720 31176133 /Users/macbook/Library/Application Support/Firefox/Profiles/33yydxv8.default/places.sqlite-journal
firefox-b 25822 macbook 25u REG 14,2 2048 535332 /Users/macbook/Library/Application Support/Firefox/Profiles/33yydxv8.default/search.sqlite
firefox-b 25822 macbook 26u REG 14,2 4096 4025097 /Users/macbook/Library/Application Support/Firefox/Profiles/33yydxv8.default/formhistory.sqlite
firefox-b 25822 macbook 27u REG 14,2 218112 4025065 /Users/macbook/Library/Application Support/Firefox/Profiles/33yydxv8.default/cookies.sqlite
firefox-b 25822 macbook 28u REG 14,2 8468 31176092 /Users/macbook/Library/Caches/Firefox/Profiles/33yydxv8.default/Cache/_CACHE_MAP_
firefox-b 25822 macbook 29u REG 14,2 2902169 31176093 /Users/macbook/Library/Caches/Firefox/Profiles/33yydxv8.default/Cache/_CACHE_001_
firefox-b 25822 macbook 30u REG 14,2 2965241 31176094 /Users/macbook/Library/Caches/Firefox/Profiles/33yydxv8.default/Cache/_CACHE_002_
firefox-b 25822 macbook 31u REG 14,2 5484544 31176095 /Users/macbook/Library/Caches/Firefox/Profiles/33yydxv8.default/Cache/_CACHE_003_
firefox-b 25822 macbook 32u REG 14,2 53817344 4025112 /Users/macbook/Library/Caches/Firefox/Profiles/33yydxv8.default/urlclassifier3.sqlite
firefox-b 25822 macbook 33u REG 14,2 7168 4025121 /Users/macbook/Library/Application Support/Firefox/Profiles/33yydxv8.default/content-prefs.sqlite
firefox-b 25822 macbook 35r REG 14,2 2167 30942053 /Applications/Firefox.app/Contents/MacOS/libwidget.rsrc
firefox-b 25822 macbook 36r REG 14,2 1200 1263195 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/Resources/QD.rsrc
firefox-b 25822 macbook 37r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 38r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 39r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 40r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 41r REG 14,2 39694 30941575 /Applications/Firefox.app/Contents/MacOS/chrome/comm.jar
firefox-b 25822 macbook 42u REG 14,2 6144 592965 /Users/macbook/Library/Application Support/Firefox/Profiles/33yydxv8.default/webappsstore.sqlite
firefox-b 25822 macbook 43r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 44r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 45r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 46r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 47r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 48u REG 14,2 4096 4025101 /Users/macbook/Library/Application Support/Firefox/Profiles/33yydxv8.default/downloads.sqlite
firefox-b 25822 macbook 49r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 50r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 51r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 52r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 53r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 54r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 55r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 56r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 57r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 58r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 59r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 60r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 61r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 62r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 63r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 64r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 65r REG 14,2 141376 29205150 /System/Library/Frameworks/QuickTime.framework/Versions/A/Resources/QuickTime.rsrc
firefox-b 25822 macbook 66r REG 14,2 56160 29205148 /System/Library/Frameworks/QuickTime.framework/Versions/A/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 67r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 68r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 69r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 70r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 71r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 72r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 73r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 74r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 75r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 76r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 77r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 78r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 79r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 80r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 81r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 82r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 83r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 84r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 85r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 86r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 87r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 88r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 89r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 90r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 91r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 92r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 93r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 94r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 95r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 96u REG 14,2 0 31177071 /private/var/tmp/etilqs_N24Uxd1PLRkwH30
firefox-b 25822 macbook 97r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 98r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 99r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 100r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 101r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 102r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 103r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 104r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 105r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 106r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 107r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 108r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 109r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 110r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 111r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 112r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 113r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 114r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 115r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 116r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 117r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 118r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 119r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 120r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 121r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 122r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 123r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 124r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 125r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 126r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 127r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 128r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 129r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 130r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 131r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 132r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 133r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 134r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 135r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 136r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 137r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 138r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 139r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 140r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 141r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 142r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 143r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 144r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 145r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 146r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 147r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 148r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 149r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 150r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 151r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 152r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 153r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 154r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 155r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 156r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 157r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 158r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 159r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 160r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 161r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 162r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 163r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 164r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 165r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 166r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 167r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 168r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 169r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 170r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 171r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 172r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 173r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 174r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 175r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 176r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 177r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 178r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 179r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 180r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 181r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 182r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 183r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 184r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 185r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 186r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 187r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 188r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 189r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 190r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 191r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 192r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 193r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 194r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 195r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 196r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 197r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 198r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 199r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 200r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 201r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 203r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 204r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 205r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 206r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 207r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 208r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 209r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 211r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 212r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 214r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 215r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 216r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 217r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 218r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 219r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 221r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 222r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 223r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 224u IPv4 0x900766c 0t0 TCP 192.168.1.105:51778->a72-246-48-17.deploy.akamaitechnologies.com:http (ESTABLISHED)
firefox-b 25822 macbook 225r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 226r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 227r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 229u IPv4 0x9977e64 0t0 TCP 192.168.1.105:51747->eh-in-f121.google.com:http (CLOSE_WAIT)
firefox-b 25822 macbook 231r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 232r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 233r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 234r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 235u IPv4 0x8b62a68 0t0 TCP 192.168.1.105:51774->a72-246-48-32.deploy.akamaitechnologies.com:http (ESTABLISHED)
firefox-b 25822 macbook 238r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 239r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 241r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 242r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 243u IPv4 0x8dfd270 0t0 TCP 192.168.1.105:51780->a72-246-48-17.deploy.akamaitechnologies.com:http (ESTABLISHED)
firefox-b 25822 macbook 245u IPv4 0x8b97e64 0t0 TCP 192.168.1.105:51934->tag.contextweb.com:http (ESTABLISHED)
firefox-b 25822 macbook 247r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 248r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
firefox-b 25822 macbook 249u IPv4 0x40ed66c 0t0 TCP 192.168.1.105:51942->a72-246-48-34.deploy.akamaitechnologies.com:http (ESTABLISHED)
firefox-b 25822 macbook 252r REG 14,2 8599 3771004 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/Flash Player.rsrc
firefox-b 25822 macbook 253r REG 14,2 286 2933625 /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Resources/English.lproj/Localized.rsrc
#314708 - 06/10/2008 10:53 Re: Problems with Firefox - OSX [Re: petteri]
Okay, that looks wrong. Do you have several dozen Flash applets open inside Firefox? I'm guessing no.
Seems to me something has gone haywire with the Flash plugin. Just to be sure, you could try disabling it and see if that prevents the problem. Tools->Add-ons->Plugins->Shockwave Flash->Disable.
Assuming it is the problem, though, I'm not sure how to resolve it while still leaving Flash active. Let's test first, huh?
