#320912 - 01/04/2009 17:57 Replacement superdrive
The superdrive in my MBP is going blind. I've had troubles with certain brands of CDR and DVDR for a while. But I've just bought a new album which is on a black CD (like the old PSone discs) and my MBP refuses to read it.
I've used ifixit.com for info replacing HD's in my Macs and I noticed that they are selling 8x superdrives at $200. Does anyone know of an OEM replacement that isn't as expensive? My local PC bits supplier has slot loading burners for £40, admittedly not a direct replacement but exactly the same specs otherwise.
According to System Profiler it's an HL-DT-ST DVDRW GWA4080MA.
#320913 - 01/04/2009 18:17 Re: Replacement superdrive [Re: andym]
Mac Drive Database (search for DVD±R/RW Drives, IDE, MBP)
Matsushita/Panasonic UJ-875-S
Pioneer DVR-K05
#320914 - 01/04/2009 18:23 Re: Replacement superdrive [Re: wfaulk]
Also check here.
#320915 - 01/04/2009 18:25 Re: Replacement superdrive [Re: andym]
It used to be that you needed specific burners for the built in Apple burning software to recognise it as a Superdrive and enable certain features. Not sure whether that is still true or not now.
#320916 - 01/04/2009 18:48 Re: Replacement superdrive [Re: tman]
Hmmm, the UJ-875-S is available from linITX who I've bought from before. But everything I've read seems to indicate it's only for the 17" MBP, mine's the 15".
However the dimensions match, as do the positions of the connectors, for £60 (versus £76 + postage from the US at Powerbook Medics) it's probably worth a punt.
Legally, what are the chances of returning it if it doesn't fit?
#320917 - 01/04/2009 18:50 Re: Replacement superdrive [Re: andym]
One of those reviews said that the 15" MBP might need a drive with the short dimension being smaller than normal.
This page shows the MBP15 drive having a "height" of 9.5mm, while the one you reference says 12.7mm.
Edited by wfaulk (01/04/2009 18:58)
#320918 - 01/04/2009 18:56 Re: Replacement superdrive [Re: tman]
Or a patch.
Apparently not:
Apple changed its strategy to exclude 3rd party burners. As far as I could test it, there is no need for Patchburn under Mac-OS X 10.5 any more!
#320920 - 01/04/2009 19:19 Re: Replacement superdrive [Re: wfaulk]
AndrewT
Loc: Oxford, UK
http://www.powerbookmedic.com/xcart1/product.php?productid=16916
Part Name: Apple SuperDrive DVD Burner Drive 8x - Macbook Pro
Apple Part #: 678-0525
Model #: UJ-857-E or UJ-857-C replaces GWA-4080M and UJ-857, also replaces combo drive CW-8221 OR 678-0525
Description:
This is a 8X Dual layer replacement Apple SuperDrive DVD-R Burner For the MacBook 13" and MacBook Pro 15". (Not compatible with Macbook Pro 17" Models, for those, use item # 16592) The drive reads DVDs (8x) and CDs (24x), burns CDs (24x or 10x rewrite), and burns DVDs (8x). (Note that there are several versions of the UJ-857, this is the fastest version 8x dual layer. There are also 2x and 6x versions of this drive on the market, so do not get confused my the model #.)
