Erm.. Drakino, there are 24pins on a Mk2!
msaeger, they will only fit one way, any good connector will have some sort of locating system on it. The power I/O should be 1 & 13 and be towards the middle of the sled/empeg.
To check, remove any power from the system and plug it in. If it docks easily, it's right. You shouldn't need to force it.
The manual has (at least mine did) a rough description of what the wires are.
Murray 06000047
I don't think, therefore I am not.
Murray
Is it the 'N', or the 'Zero'?
