#327037 - 25/10/2009 00:25 Help with DNS problems?
TigerJimmy
Hey everybody,
I haven't done anything with this in so long I'm really rusty on most of it. I've been running a web server and DNS server for supporting my telco so I needed to change ISPs, and thus IP addresses for the first time in 10 years.
I changed the A records of my bind configuration files to the new IP address and reloaded the name server, but the changes aren't propagating to the world. I've obviously done something wrong. All I did was update the serial number and change the IP address entries, for example, from:
ns1.tigerjimmy.com. IN A 209.98.143.194
to:
ns1.tigerjimmy.com. IN A 173.85.248.18
then did a kill -HUP on named. The log files show that the zones loaded.
Can anyone give me a hint on what I forgot here?
Thanks in advance,
Jim
#327038 - 25/10/2009 00:44 Re: Help with DNS problems? [Re: TigerJimmy]
What is the TTL set to for your domain? It'll be cached for that amount of time.
#327039 - 25/10/2009 00:59 Re: Help with DNS problems? [Re: tman]
TigerJimmy
24 hours, but I made the change 2 days ago. Also, when I run an nslookup from a remote machine I get a nonexistent domain error...
#327040 - 25/10/2009 01:30 Re: Help with DNS problems? [Re: TigerJimmy]
If you are changing your DNS server IP for *.tigerjimmy.com, you need to tell one level up don't you? i.e. your DNS registrar.
#327041 - 25/10/2009 01:53 Re: Help with DNS problems? [Re: Shonky]
TigerJimmy
Well, I thought I had done this, but it appears that the change was not committed. The registrar still had the old IP address for the name server. Thanks for reminding me to check the obvious!
