Hm, where is this default MkII config file? All my previous kernels were done with a config file found on this BBS several months ago. Do you have a config file you can arm me with? I can do a make menuconfig but I really don't know what to change in there.
Here are my bootup messages... I can't see anything abnormal in there.
e000 v1.03
Copying kernel...
Calling linux kernel...
Linux version 2.2.14-rmk5-np17-empeg43 (root@spaz) (gcc version 2.95.2 19991024 (release)) #2 Sat Jun 30 19:59:20 EDT 2001
empeg-car player (hardware revision 7, serial number 80000554)
Command line: mem=12m temp=31
Memory: 10944k/12M available (1024k code, 20k reserved, 292k data, 8k init)
Linux NET4.0 for Linux 2.2
NET4: Unix domain sockets 1.0 for Linux NET4.0.
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005800).
empeg single channel IDE
Probing primary interface...
hdb: IBM-DJSA-220, ATA DISK drive
hda: IBM-DARA-218000, ATA DISK drive
hda: IBM-DARA-218000, 17301MB w/418kB Cache, CHS=35152/16/63
hdb: IBM-DJSA-220, 17297MB w/1874kB Cache, CHS=37488/15/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:02:2a
Partition check:
hdb: hdb4
empeg-pump v0.03 (19980601)
ÈTrying to unmount old root ... okay
Freeing unused kernel memory: 8k initI see this is a developer image!
Mounting proc
Press 'q' now to go into development mode. You Have Zero Seconds To Comp
Starting player
empeg-car 1.03.
E !! player.cpp 238: MainThread::Init failed!
Restored terminal settings
Player exited normally: 0
Starting bash.
empeg:/empeg/bin#
-Tony
MkII #554
