#33634 - 30/06/2001 19:29 1.03 Kernel Issues
Happy Birthday tonyc
I have successfully compiled and installed many kernels prior to 1.03. However, I'm having problems getting it to work this time. I started from the beta 11d source tree, and applied each of the patches in order until it was patched to 1.03. Compiled fine, and the kernel boots. However, when the player starts, It goes through several startup messages before getting stuck on
"Starting poll thread failed"
It then drops to a bash prompt.
What's going on here? I tried re-applying the 1.03 upgrade and then uploading the kernel, same effect, so that means it's something wrong with the kernel rather than something on my hard disk or in my init that is screwing things up... None of my patches failed or reported errors, and the kernel seems to be valid. It just causes the player to not run properly. What is the poll thread, and what about my kernel could cause that thread to fail to start? Thanks in advance for any help.
#33635 - 01/07/2001 11:34 Re: 1.03 Kernel Issues [Re: tonyc]
fvgestel
Loc: Netherlands
I had the same messages when the player couldn't read from some device files. I also had it when the kernel was missing some devices.
I always used "make menuconfig", but that has resulted in some strange compilation errors. After copying the default MK2-config file and editing it by hand, the compile went OK and all devices were compiled in.
Try checking your device files first ( wrong major/minor numbers? ), and then check the boot messages to see if there are devices missing.
You can also try to start the player without serial / USB support.
Frank van Gestel
Frank van Gestel
#33636 - 01/07/2001 12:06 Re: 1.03 Kernel Issues [Re: fvgestel]
Hm, where is this default MkII config file? All my previous kernels were done with a config file found on this BBS several months ago. Do you have a config file you can arm me with? I can do a make menuconfig but I really don't know what to change in there.
Here are my bootup messages... I can't see anything abnormal in there.
e000 v1.03
Copying kernel...
Calling linux kernel...
Linux version 2.2.14-rmk5-np17-empeg43 (root@spaz) (gcc version 2.95.2 19991024 (release)) #2 Sat Jun 30 19:59:20 EDT 2001
empeg-car player (hardware revision 7, serial number 80000554)
Command line: mem=12m temp=31
Memory: 10944k/12M available (1024k code, 20k reserved, 292k data, 8k init)
Linux NET4.0 for Linux 2.2
NET4: Unix domain sockets 1.0 for Linux NET4.0.
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005800).
empeg single channel IDE
Probing primary interface...
hdb: IBM-DJSA-220, ATA DISK drive
hda: IBM-DARA-218000, ATA DISK drive
hda: IBM-DARA-218000, 17301MB w/418kB Cache, CHS=35152/16/63
hdb: IBM-DJSA-220, 17297MB w/1874kB Cache, CHS=37488/15/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:02:2a
Partition check:
hdb: hdb4
empeg-pump v0.03 (19980601)
ÈTrying to unmount old root ... okay
Freeing unused kernel memory: 8k initI see this is a developer image!
Mounting proc
Press 'q' now to go into development mode. You Have Zero Seconds To Comp
Starting player
empeg-car 1.03.
E !! player.cpp 238: MainThread::Init failed!
Restored terminal settings
Player exited normally: 0
Starting bash.
empeg:/empeg/bin#
-Tony
MkII #554
#33637 - 01/07/2001 12:32 Re: 1.03 Kernel Issues [Re: tonyc]
fvgestel
Loc: Netherlands
There should be some in the source tree. The patches also contain these.
They can be found under arch/arm/def-configs/
Frank van Gestel
Frank van Gestel
#33638 - 01/07/2001 13:36 Re: 1.03 Kernel Issues [Re: fvgestel]
Thanks, things are working now!
-Tony
MkII #554
