Well, my "strangest place for an empeg" has come to an end, at least temporarily. My empeg is dead.
Not the empeg's fault, and not the bike install's fault, either. More like an act of God.
I stopped at the local NAPA store to get a new alternator for my car, and not wanting to leave the empeg sitting out in plain sight (I hadn't yet followed msaeger's suggestion of getting a blank plate to hide the empeg while it was on my bike
) I stuffed it down in one of my saddlebags, under some clothes, figured it would be pretty safe that way.
While I was in the store, the wind came up, blew the bike over and it landed on the saddlebag containing the empeg -- probably about an 18" fall with minimal padding protecting the empeg.
Now, it no longer boots up. The screen lights up, shows the bootup logo, but that's as far as it goes. It acts just like a hard drive cable has come unplugged. That is not the case, however -- I have my empeg disassembled in front of me as I type this, and I can power it up and hear the hard drive spin, but no boot. Below is what Hyperterminal displays when I try to boot. I have no idea what any of it means... can anybody translate this into words of one syllable or less that I might be able to understand?
e000 v1.03
Copying kernel...
Calling linux kernel...
Uncompressing Linux................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg45 (roger@aphex.internal.empeg.com) (gcc ver
sion 2.95.2 19991024 (release)) #29 Tue Mar 27 18:21:21 BST 2001
empeg-car player (hardware revision 7, serial number 80000267)
Command line: mem=12m temp=42
Memory: 11008k/12M available (956k code, 20k reserved, 296k data, 8k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is ffffffff ' '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
Could not find CS4231A (version=80)
empeg state support initialised 0089/88c1 (save to d0004500).
empeg single channel IDE
Probing primary interface...
smc chip id/revision 0x3333
smc_init couldn't find card
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
Given the circumstances, I would guess that my hard drive is hosed. I notice that it seems to rattle a bit when I shake it or even turn it over in my hands. And while it is still technically under warranty, I wouldn't feel right about asking for warranty repair. If it doesn't work after falling onto a concrete sidewalk, that's hardly a failure of workmanship or materials...
Anyway, if anybody has any magic ideas about bringing my empeg back to life, I'm all ears.
