Do you have a specific tool for this purpose?
I used
iperf.
One side runs a server:
[tman@ideal ~]$ iperf -s
Server listening on TCP port 5001
TCP window size: 85.3 KByte (default)
The other side runs the client:
[tman@storage ~]$ iperf -c ideal
Client connecting to ideal, TCP port 5001
TCP window size: 16.0 KByte (default)
[ 3] local 192.168.1.20 port 44971 connected with 192.168.1.50 port 5001
[ ID] Interval Transfer Bandwidth
[ 3] 0.0-10.0 sec 1.08 GBytes 928 Mbits/sec
Two machines which are connected via GigE to the same switch. It doesn't hit the disk at all for anything so it should be fairly close to the theoretical maximum for that link with those parameters assuming nothing else is using the network.
One side is using conventional PCI with only a single link so if I run a dual ended test where it tests speed in both directions at the same time, I get limited to 430Mbps + 638Mbps which is 1068Mbps and for some reason it uses 1000 instead of 1024 when calculating bps so its actually 1018Mbps which is just under the 1064Mbps (133MBps) that a 32 bit 33MHz conventional PCI card can do.
[tman@storage ~]$ iperf -c ideal -d
TCP window size: 487 KByte (default)
[ 5] local 192.168.1.20 port 55051 connected with 192.168.1.50 port 5001
[ 4] local 192.168.1.20 port 5001 connected with 192.168.1.50 port 47713
[ 5] 0.0-10.0 sec 513 MBytes 430 Mbits/sec
[ 4] 0.0-10.0 sec 762 MBytes 638 Mbits/sec
The other side is 4 lane PCI-e but the only other machines I've got which are PCI-e all run ESX so I'd need to run it on the service console.
