#34174 - 09/07/2001 07:16
how will this drive do as my 2nd drive in my mk2
http://www.officeexpress.com/solutions/item.asp?sku=407609TD&S=704G
THANKS
#34175 - 09/07/2001 07:29
Re: how will this drive do as my 2nd drive in my mk2
[Re: silvercas]
The IBM spec sheet seems to suggest that it's fine. The 4200 RPM spin speed should give it quiet operation and the height is within spec for the drive tray. I reckon it should be fine.
Just follow the FAQs of the installation and all should be groovy. Murray 06000047
I don't think, therefore I am not.
Murray
Is it the 'N', or the 'Zero'?
#34176 - 09/07/2001 22:14
[Re: muzza]
Loc: Scottsdale, AZ USA
By the way - there is a utility available on the IBM website for changing the operating characteristics of the travelstar drives. You can set the drive to "quiet" operation or "performance" - which is default.
If you have noisy IBM drives, you might want to check that utility out - it's available as a link off the tech specs for the drive above.
______________________________________ Queue 351, Now Mk II #60000022 18gb, Blue
Queue 351,
Mk I, 30GB
Mk II #60000022 80gb, Blue - docked
Mk2a, 80GB, Bruface, lighted buttons and dial
#34177 - 10/07/2001 05:40
[Re: Clarke]
Loc: Meije, Netherlands
there is a utility (..) on the IBM website for changing the operating characteristics of the travelstar drives (..) to "quiet"
I too have a Travelstar second hard drive, which rattles more than the original (Toshiba ?) that came with the empeg. Tried to find the utility you talk about, but can't find it. Any pointers? Thanks
Henno
mk2 6 nr 6
Henno
mk2 [orange]6 [/orange]nr 6
#34178 - 10/07/2001 07:20
[Re: Henno]
Loc: Druten, The Netherlands
IBM Feature ToolEdwin de Vaan
mk2 rev.7 Trillian # 080000263 6+20Gb blue/red
[white]ญญ______________[/white] Edwin de Vaan aka FLaSHmAStER
#34179 - 10/07/2001 08:00
[Re: edwin]
Hrmm... The "Linux" version of this feature tool requires a floppy disk. I looked at my empeg several times but wasn't able to locate a floppy drive. :)
Guess you'd have to take the drive out of your empeg, connect it to a notebook PC to run this utility, and reinstall it in your empeg....
-Tony
MkII #554
#34180 - 10/07/2001 08:10
[Re: tonyc]
The setting isn't permanent, so it won't survive reboots as I remember. You could write a little program to do the ioctl to send the appropriate ATA command quite easily, but this just quietens the seeks (by slowing them down). I doubt it's worth it for the carplayer!
#34181 - 10/07/2001 09:17
[Re: Henno]
IBM Feature Tool:
http://www.storage.ibm.com/techsup/hddtech/welcome.htm
Queue 351,
Mk I, 30GB
#34182 - 10/07/2001 10:02
[Re: altman]
Wouldn't slowing the drives down also reduce heat? That might be useful for the car player. ___________
#34183 - 10/07/2001 11:13
No significant heat comes from seeking - it's almost all from the motor and drivers. The commands don't make the drive rotate any slower.
#34184 - 10/07/2001 11:20
[Re: altman]
Interesting! Now I understand.
Still, I could see how reducing seek noise could be a benefit in the car player. I mean, if you're parked with the engine off, and you're making the moves on your girlfriend, it would be good to keep disk-seek noise from reducing the effectiveness of the Barry White you've got playing. ___________
#34185 - 10/07/2001 14:17
Loc: Penarth, UK
What do you need a girlfriend for if you have an Empeg ?
Rod, UK Mk2 64gig Red S/No.341 2xDell RioReceiver
- -- Rod, UK
#34186 - 10/07/2001 14:31
[Re: mardibloke]
So you can have a use for WendyFilters when 1.1 comes out. ___________
#34187 - 10/07/2001 14:32
[Re: mardibloke]
If you kinda happen to have the 'likes-to-talk-a-lot-about-anything' type of girlfriend, as I do, you can crank up the volume to a certain level she doesn't even try to reach. The anecdote about birds tweetering themselves to death comes to mind... Hehe, just a stupid answer to a stupid question!!! ;o)
Edwin de Vaan
#34188 - 10/07/2001 14:34
Loc: Penarth, UK
Good point, well made ![](/images/icons/smile.gif) - --
- -- Rod, UK
#34189 - 10/07/2001 14:35
[Re: edwin]
Loc: Penarth, UK
Are you suggesting my question was stoopid ? ![](/images/icons/wink.gif) - --
- -- Rod, UK
#34190 - 10/07/2001 14:47
[Re: mardibloke]
No, you just forgot to mention boyfriend, or better yet change it to 'partner' as this is the most obvious word to choose nowadays, that's always right, right?!?!?. Edwin de Vaan
