Page 2 of 2 < 1 2
#344383 - 19/04/2011 19:53 Re: Long Term Data Backup [Re: Cris]
Happy Birthday tanstaafl.
Originally Posted By: Cris
As for the safe, it's rated to keep the internal temp below a max 177 degrees celsius for 2 hours.
I'm guessing that is under conditions of a "typical" house fire. What if the fire burns longer than two hours?
In any case, I doubt that a hard drive would survive for any length of time at 177 degrees C (350 degrees F). All the plastic bits would melt, possibly the case would warp, and you are actually perilously close to the melting point of many common solder alloys.
I think the best you could hope for would be that the platters themselves might be undamaged enough that a recovery $peciali$t might be able to save some of the data.
#344384 - 19/04/2011 20:10 Re: Long Term Data Backup [Re: tanstaafl.]
I thought that too, but the same would apply for DVDs and USB sticks too. One advantage of living in a newly built house is the general level of fire protection is pretty good. As it's over 3 levels the building regs state firedoors have to be fitted, which should hold back quite a bit of a blaze for a good 30 minutes.
I think this is all so in my mind I can say I took all reasonable actions. It's also nice to meet my insurance requirements for any cash etc... I hold.
#344425 - 21/04/2011 05:15 Re: Long Term Data Backup [Re: Cris]
matthew_k
I've always found the idea of putting digital media in a fire safe bizarre. It's digital - make two copies, separate them geographically. A fire is far less likely to happen than a drive failure.
My rule of thumb - if it's not spinning in two places, it's as good as gone.
#344428 - 21/04/2011 08:07 Re: Long Term Data Backup [Re: Cris]
I was worried about the drive being spun up in the safe the whole time, but tests this afternoon have shown that is successfully spins down after a short period. Bonus! I was worried about the drive heating up in the safe and the hot air not having anywhere to go.
You use the drive whilst its in the safe?
#344430 - 21/04/2011 09:43 Re: Long Term Data Backup [Re: tman]
Yea, that is the whole point. Like I said I'm real lazy, the drive int he safe acts as a temporary 2nd backup of the RAWs and is done automatically on import into Lightroom. Once the Wedding is edited the job is archived onto another drive to be kept offline in the safe, freeing up more space for the next job and so on.
The thing I want is to always have at least 2 copies of the RAWs and 3 (one offsite) of the JPGs.
After a couple of years I'd be happy to go down to 1 copy of the RAWs for longer term archive.
#344440 - 21/04/2011 14:54 Re: Long Term Data Backup [Re: Cris]
So the drive is permanently connected? How do you get the wires in/out of the safe?
#344445 - 21/04/2011 16:13 Re: Long Term Data Backup [Re: tman]
It has USB through the door
#344451 - 21/04/2011 17:25 Re: Long Term Data Backup [Re: mlord]
Thank you Mark smile
There is no hole, it's wired in with the door mech. It's the only one I could find that would allow me to do this without spending a fortune.
Page 2 of 2 < 1 2
