#351077 - 23/03/2012 13:35 Need An MP3 Player With Start Button Connection
I am in the need of a really simple mp3 player that I can start form a simple short connection.
It's for timing fireworks to music, so I need the mp3 player to trigger from our firework trigger system.
My Google-fu hasn't turned up anything yet, but I thought this could be the perfect place to ask smile
#351080 - 23/03/2012 13:53 Re: Need An MP3 Player With Start Button Connection [Re: Cris]
robricc
Maybe you could modify something like this?
EDIT: Cheaper here and looks a bit simpler.
Edited by robricc (23/03/2012 13:56)
#351082 - 23/03/2012 14:52 Re: Need An MP3 Player With Start Button Connection [Re: Cris]
I'm trying to infer from context here that you're looking for a physical portable MP3 player device, right?
Most iPods can be controlled by a button on the headphone cable.
If you look closely, iPod and iPhone headset plugs, the ones with the inline button dealybobs, aren't just tip-ring-sleeve, they are tip-ring-ring-sleeve. That extra ring is for the control interface. I think it's just resistance values, and you could wire up something that fired off the iPod on command pretty easily. I'll see if I can find a resistance value reference.
#351083 - 23/03/2012 15:00 Re: Need An MP3 Player With Start Button Connection [Re: tfabris]
This Thread implies that if you merely want play/pause, you just short that extra ring to ground briefly.
If you want more fancy, you need more circuitry to control the signaling on that connector.
#351084 - 23/03/2012 15:17 Re: Need An MP3 Player With Start Button Connection [Re: tfabris]
If you could use a little laptop/netbook as an MP3 player, one idea is to take apart a USB Mouse. You could just take the wires for the short connection, piggy them up to the left mouse click button and probably blind out the sensor/take out the ball whatever as well.
Use the trackpad on the laptop to hover over the 'play' button in your MP3 player software and your short out connection should hit the button for you. Hopefully.
#351085 - 23/03/2012 15:20 Re: Need An MP3 Player With Start Button Connection [Re: sein]
Although you will need to release the short connection for the mouse click to register.
#351086 - 23/03/2012 15:55 Re: Need An MP3 Player With Start Button Connection [Re: sein]
I was really looking for something a little more robust, like an embedded solution. This is going to be used in some pretty terrible conditions, and wired to a PA of some kind. So I wanted something I could just hook upto without any dodgy homebrew wiring.
#351087 - 23/03/2012 16:22 Re: Need An MP3 Player With Start Button Connection [Re: robricc]
Raspberry Pi?
Audio out - should boot very quickly - runs linux - designed for I/O control.
#351088 - 23/03/2012 16:24 Re: Need An MP3 Player With Start Button Connection [Re: Cris]
robricc
Maybe you could put a kit like this into a weatherproof box?
http://www.quasarelectronics.com/velleman/k8095-mp3-player-kit.htm
#351089 - 23/03/2012 16:25 Re: Need An MP3 Player With Start Button Connection [Re: Cris]
I think a solid-state MP3 player such as an iPod Nano would be the most robust, then. Triggering its play button via a relay connected to its headphone jack would probably be the most reliable thing. And because solid state MP3 players are cheap and plentiful, you could, in theory, have multiple hot spares on hand if one malfunctions.
What you haven't described is the mechanism by which the fireworks launch system can trigger the play function on the audio. Is it a relay wired up to a connector or what? I don't know what these systems look like. You'd think that if the system had a way to trigger audio-start, that they'd also *already* sell an interface just for this purpose.
#351090 - 23/03/2012 18:26 Re: Need An MP3 Player With Start Button Connection [Re: tfabris]
sn00p
Loc: South London
Much as it pains me to suggest it....but....
http://www.sparkfun.com/tutorials/295
Arduino + MP3 Player Shield + minor effort will allow you to do exactly what you want. Stick it in a case and you should have a pretty robust system.
#351091 - 23/03/2012 19:10 Re: Need An MP3 Player With Start Button Connection [Re: robricc]
This looks the ticket! I'll look into it smile
This is what will trigger it...
http://www.cobrafiringsystems.com/index.php?route=product/product&product_id=51
I think they are working on their own solution for this, but I want something to work with now.
#351092 - 23/03/2012 19:23 Re: Need An MP3 Player With Start Button Connection [Re: Cris]
You could try this.
Seems to do what you need.
#351097 - 23/03/2012 22:17 Re: Need An MP3 Player With Start Button Connection [Re: pca]
Or just buy something made for the purpose...
https://www.gilderfluke.com/index.php?ma...u34hl9bi3b4nl5p
#351102 - 23/03/2012 23:36 Re: Need An MP3 Player With Start Button Connection [Re: pca]
Originally Posted By: pca
You could try this.
That would be just perfect, if it could read from a USB Flash Drive! Bummer. I'll keep looking.
#351106 - 24/03/2012 06:27 Re: Need An MP3 Player With Start Button Connection [Re: Cris]
Happy Birthday andy
Surely you can just stick the microSD card into a USB adapter ?
http://www.sparkfun.com/datasheets/Widgets/MP3Trigger/MP3TriggerV2UserGuide_2010-07-30.pdf
#351107 - 24/03/2012 06:46 Re: Need An MP3 Player With Start Button Connection [Re: andy]
Yea, I could, but the mounting options are limited for SD, and in the conditions it's going to have to work under I would much prefer to use a robust USB key to hold the tracks on rather than a tiny and very easy to loose micro-SD. I might give this trigger mp3 a go as it's perfect in every other way, and pretty cheap!
