#3512 - 21/12/1999 00:34
Emplode disk space reporting is buggy
After a few nasty crashes with Beta 8A (I've since upgraded) Emplode is reporting that my unit has only 1147 of 5624 mb available with all playlists deleted. Obviously the mp3s uploaded before one (or during each) of the crashes still occupy space on the unit and are hiding from Emplode.
My question is this: Is this problem only fixable via Linux? Cause if so thats a major bummer. For reasons that will go unmentioned I was forced to delete my Linux drive two weeks back. Reinstalling will be a major pain :( I am open to a complete disk wipe if it will solve this problem and if it can be done within the feeble confines of windoze.
I'm holding out hope I can get this problem resolved before my New Years road trip to Vegas.
Bigfro
#3513 - 21/12/1999 07:38
Re: Emplode disk space reporting is buggy
[Re: bigfrobro]
Loc: Florida
If you have the developer image installed, you should be able to connect a terminal to the player using an emulator like HyperTerminal, although there are much better emulators.
_~= Dearing =~_ "WAY too happy about having #99."
_~= Dearing =~_ Gettin' back into it thanks to slimrio!
#3514 - 21/12/1999 13:44
[Re: Dearing]
Well here's the whole darn thing...I'm a little worried about line 52, but honestly I'm stumbling around in the dark here. I’ve tried various minor tweaks like deleting the contents of var, even fdisking the whole shebang. No luck. Emplode still only reports about a gig and a half out of 6 as available. I'll keep scouring the boards for clues but I could really use a little handholding at this point :)
Edit: I exported my database out of curiosity and got a LONG list of "tunes". Below is a sample. These seem to be the culprits, now how do i delete them?
"fid","type","length","title","artist","genre","year","comment","source","refs" 16,"playlist","0","empeg-car","","","","","",1 17,"playlist","4764","Unattached items","","","","","",2 19,"tune","3645440","A New Hope","Blink 182","Rock","","","Dude Ranch",2 20,"tune","2772992","Emo","Blink 182","Rock","","","Dude Ranch",2 21,"tune","2734080","Enthused","Blink 182","Rock","","","Dude Ranch",2 22,"tune","5449728","I'm Sorry","Blink 182","Rock","","","Dude Ranch",2 23,"tune","3241984","Josie","Blink 182","Rock","","","Dude Ranch",2 24,"tune","2574336","Lemmings","Blink 182","Rock","","","Dude Ranch",2 25,"tune","2412544","Pathetic","Blink 182","Rock","","","Dude Ranch",2 26,"tune","2709504","Untitled","Blink 182","Rock","","","Dude Ranch",2 27,"tune","2666496","Voyeur","Blink 182","Rock","","","Dude Ranch",2 28,"tune","3190784","Waggy","Blink 182","Rock","","","Dude Ranch",2 29,"tune","2797568","Apple Shampoo","Blink 182","Rock","","","Dude Ranch",2 30,"tune","1669120","Boring","Blink 182","Rock","","","Dude Ranch",2 31,"tune","2689024","Dammit","Blink 182","Rock","","","Dude Ranch",2 32,"tune","2416640","Degenerate","Blink 182","Rock","","","Dude Ranch",2
Resume old post
1 Clearing 8Mb of RAM... 2 Copying kernel... 3 Calling linux kernel... 4 Uncompressing Linux...done. 5 Now booting the kernel 6 Linux version 2.2.12-rmk1-np12-empeg18 (mac@fatboy.internal.empeg.com) (gcc 7 vers 7 ion egcs-2.91.66 19990325/philb (egcs-1.1.2 release)) #70 Wed Dec 1 15:53:17 GMT 8 1999 9 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. 10 Command line: 11 Calibrating delay loop... 208.08 BogoMIPS 12 Memory: 7352k/8M available (568k code, 20k reserved, 248k data, 4k init) 13 POSIX conformance testing by UNIFIX 14 Linux NET4.0 for Linux 2.2 15 Based upon Swansea University Computer Society NET3.039 16 Starting kswapd v 1.5 17 SA1100 serial driver version 4.27 with no serial options enabled 18 ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART 19 ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART 20 ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART 21 Linux video capture interface: v1.00 22 empeg FM radio driver (Philips). 23 empeg audio driver initialized 24 empeg infra-red support initialised. 25 empeg usb initialised, USBN9602 revision 1 26 empeg display initialised. 27 empeg state support initialised (save to d0004980). 28 empeg RDS driver initialised 29 RAM disk driver initialized: 16 RAM disks of 4096K size 30 empeg dual channel IDE 31 Probing primary interface... 32 No drives found, retrying... 33 hda: IBM-DARA-206000, ATA DISK drive 34 No drives found, retrying... 35 No drives found, retrying... 36 Registering drives... 37 ide0 at 0x040-0x047,0x078 on irq 7 38 hda: IBM-DARA-206000, 5729MB w/418kB Cache, CHS=12416/15/63 39 Partition check: 40 hda: hda1 < hda5 hda6 > hda2 hda3 hda4 41 RAMDISK: ext2 filesystem found at block 0 42 RAMDISK: Loading 320 blocks [1 disk] into ram disk... done. 43 VFS: Mounted root (ext2 filesystem). 44 empeg-pump v0.03 (19980601) 45 Press Ctrl-A to enter pump...VFS: Mounted root (ext2 filesystem) readonly. 46 change_root: old root has d_count=1 47 Trying to unmount old root ... okay 48 Freeing unused kernel memory: 4k initI see this is a developer image! 49 Mounting proc 50 Mounting first music partition 51 Mounting second music partition 52 Tried to mount /drive1 but got error 15 53 Error mounting partitions (possibly already mounted) 54 Remounting first music partition read-only 55 Remounting second music partition read-only 56 No secondary hard disk 57 Press 'q' now to go into development mode. You Have Zero Seconds To ComplùStarti 58 ng player 59 q 60 Restored terminal settings 61 Remounting first music partition read-only 62 Remounting second music partition read-only 63 No secondary hard disk 64 Player exited normally: 0 65 Switching to shell-player loop 66 Starting bash. 67 empeg:/empeg/bin#
#3515 - 21/12/1999 15:16
[Re: bigfrobro]
If you really want to blank the entire disk, you need to get to a shell, erase the contents of /empeg/var *and* /empeg/fids, remount read-only, sync a few times, exit the shell (restarts the player) then connect with the pc software again.
However, your tunes have most likely been put in the unattached items playlist. Does this appear for you in emplode?
#3516 - 21/12/1999 15:26
[Re: altman]
Hugo,
No, according to the export file all playlists are empty and the Emplode screen is blank (see my last post for more details). They are listed as type "tune" in no particular playlist. Deleting them I believe will free up the lost disk space, but as I mentioned in the opening access to a Linux shell is a pretty remote possibility at this point. If you haven't already please take a look at my last post and see if any of the info there illuminates the situation.
Bigfro
#3517 - 21/12/1999 15:48
[Re: bigfrobro]
Thought I'd mention - if your trip to Vegas is for CES then we'll be there, in the Digital Music Pavillion. Booth 6623 from memory.
#3518 - 22/12/1999 01:00
[Re: altman]
Loc: Sunnyvale, CA
FWIW, I had the same problem, really quite identical, and my songs don't show up in the unattached list either. In fact, I can no longer get an unattached list (I tried to force it ;-) and I'm out about 2 gigabytes.
Interestingly enough, I notice that when I do a search (what's that button I hit on the remote? Always get there accidentally, end up being asked for a PIN, hit enter, and up comes a list of songs) I can see all the tunes that I lost that are now occupying the missing 2 gigabytes, but I don't know how to get to them to delete them. They're not on any playlist, I swear.
I second the motion: some handholding would be nice here. I can get to the shell on the developer image via the serial port, but I don't have access to a linux box (other than the empeg, of course ;-)
jester Sunnyvale, CA MkI / 20GB / Blue / SN00309
#3519 - 22/12/1999 05:17
[Re: jester]
I think the solution here is to fix the bugs in the empeg software so that these tunes appear in the "unattached" playlist. That way, you (a) don't lose the tunes and (b) the existing software should sort it out.
Search can be got to by pressing "direct ok" on the remote. One press - pin, two - year, three - search by title, four - search by artist, five - search by genre.
#3520 - 22/12/1999 07:27
[Re: bigfrobro]
Loc: Florida
I'm going to Vegas for New Years, too. It's a shame I'm coming home on the 4th, and the CES starts on the 7th; I would have liked to meet the Empeg team.
#3521 - 22/12/1999 09:03
[Re: bigfrobro]
Loc: Cambridge, UK
I've modified emplode to export the contents of playlists to CSV in addition to the current output as a debugging aid for solving this problem.
If you'd like to email support@empeg.com I can send you a copy.
-- Mike Crowe I may not be speaking on behalf of empeg above :-)
-- Mike Crowe
#3522 - 22/12/1999 12:06
[Re: Dearing]
We're arriving sometime on the 4th - not sure when though...
