Hey there! Thanks for the reply.
Wow -- that sucks...
Meanwhile, I've never set up jEmplode for pushing empeg images...
I'm using CentOS 6.x which has the RXTX library available from EPEL... (which I installed)
but when I run jEmplode, I still get:
java.lang.NoClassDefFoundError: javax/comm/CommPortIdentifier
This is what the RPM package provides:
/usr/lib64/rxtx
/usr/lib64/rxtx/librxtxI2C-2.2pre1.so
/usr/lib64/rxtx/librxtxI2C.so
/usr/lib64/rxtx/librxtxParallel-2.2pre1.so
/usr/lib64/rxtx/librxtxParallel.so
/usr/lib64/rxtx/librxtxRS485-2.2pre1.so
/usr/lib64/rxtx/librxtxRS485.so
/usr/lib64/rxtx/librxtxRaw-2.2pre1.so
/usr/lib64/rxtx/librxtxRaw.so
/usr/lib64/rxtx/librxtxSerial-2.2pre1.so
/usr/lib64/rxtx/librxtxSerial.so
/usr/share/doc/rxtx-2.2
/usr/share/doc/rxtx-2.2/AUTHORS
/usr/share/doc/rxtx-2.2/COPYING
/usr/share/doc/rxtx-2.2/ChangeLog
/usr/share/doc/rxtx-2.2/INSTALL
/usr/share/doc/rxtx-2.2/README
/usr/share/doc/rxtx-2.2/TODO
/usr/share/java/RXTXcomm.jar
In the longer form of the error box that pops up in jEmplode:
at org.jempeg.empeg.manager.dialog.UpgraderDialog.<init>(UpgraderDialog.java:155)
at org.jempeg.empeg.manager.dialog.UpgraderDialog.<init>(UpgraderDialog.java:114)
at org.jempeg.empeg.manager.action.UpgradeAction.actionPerformed(UpgradeAction.java:62)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
at javax.swing.AbstractButton.doClick(AbstractButton.java:376)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:833)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:877)
at java.awt.Component.processMouseEvent(Component.java:6516)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3311)
at java.awt.Component.processEvent(Component.java:6281)
at java.awt.Container.processEvent(Container.java:2229)
at java.awt.Component.dispatchEventImpl(Component.java:4872)
at java.awt.Container.dispatchEventImpl(Container.java:2287)
at java.awt.Component.dispatchEvent(Component.java:4698)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422)
at java.awt.Container.dispatchEventImpl(Container.java:2273)
at java.awt.Window.dispatchEventImpl(Window.java:2718)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747)
at java.awt.EventQueue.access$300(EventQueue.java:103)
at java.awt.EventQueue$3.run(EventQueue.java:706)
at java.awt.EventQueue$3.run(EventQueue.java:704)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:86)
at java.awt.EventQueue$4.run(EventQueue.java:720)
at java.awt.EventQueue$4.run(EventQueue.java:718)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:717)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:218)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:133)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:122)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:118)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:110)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
Caused by: java.lang.ClassNotFoundException: javax.comm.CommPortIdentifier
at java.net.URLClassLoader$1.run(URLClassLoader.java:359)
at java.net.URLClassLoader$1.run(URLClassLoader.java:348)
at java.net.URLClassLoader.findClass(URLClassLoader.java:347)
at java.lang.ClassLoader.loadClass(ClassLoader.java:425)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:312)
at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
... 41 more
But do I need to do anything else? (how do I test the jar file is being referenced properly? I assume it is having been packaged by the EPEL folks..)
(I created javax.comm.properties in /usr/lib/java/ but that doesn't seem to help.)
Thanks,
-Ben
