Ok, here's the bootlog on home power.
empeg-car v0.07 19991106 (hugo@empeg.com)
e000 v1.03
Copying kernel...
Calling linux kernel...
Uncompressing Linux....................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg43 (root@linux) (gcc version 2.95.2 19991024
(release)) #1 Wed Jul 18 20:20:45 MDT 2001
Processor: Intel StrongARM-1100 revision 9
empeg-car player (hardware revision 4, serial number 00317)
Command line: mem=8m temp=27
Memory: 7356k/8M available (580k code, 20k reserved, 228k data, 8k init)
Dentry hash table entries: 1024 (order 1, 8k)
Buffer cache hash table entries: 8192 (order 3, 32k)
Page cache hash table entries: 2048 (order 1, 8k)
Linux NET4.0 for Linux 2.2
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg remote control/panel button support initialised (Using FIQs).
A25D0A->B94614 10640650->12142100
A25D0B->B94615 10640651->12142101
A25D43->B9460B 10640707->12142091
A25D42->B9460A 10640706->12142090
A25D12->B9465E 10640658->12142174
A25D1A->B9461F 10640666->12142111
A25D0C->B9460E 10640652->12142094
A25D40->B9461B 10640704->12142107
A25D41->B9460F 10640705->12142095
A25D19->B94603 10640665->12142083
A25D0D->B94600 10640653->12142080
empeg usb initialised, USBN9602 revision 1
empeg state support initialised 0089/8893 (save to d0005680).
empeg RDS driver initialised
empeg power state driver initialised
Linux video capture interface: v1.00
empeg FM radio driver (Philips).
empeg dual channel IDE
Probing primary interface...
No drives found, retrying...
hda: TOSHIBA MK1011GAV, ATA DISK drive
hdc: TOSHIBA MK1011GAV, ATA DISK drive
Registering drives...
ide0 at 0x040-0x047,0x078 on irq 7
ide1 at 0x000-0x007,0x038 on irq 6
hda: TOSHIBA MK1011GAV, 9590MB w/0kB Cache, CHS=19485/16/63
hdc: TOSHIBA MK1011GAV, 9590MB w/0kB Cache, CHS=19485/16/63
Partition check:
hdc: hdc1 hdc2 hdc3 hdc4
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 8k initI see this is a developer image!
Mounting proc
Starting player
empeg-car 1.03-rc1.
Veiko
veiko@lc.ee
MK1 #317 - 20GB green
