#374706 - 04/08/2025 23:11 Unable to connect Using Ethernet cable
Ladmo
Loc: Oklahoma
I am using emplode 2.0
I'm unable to get the connection to the player using Ethernet. I have tried using Crossover cable, straight through cable. I am not sure about the settings. I think I just choose Network. The address in the box below that is 255.255.255.255. I am not sure if I need to check that box also or if I need change the 255.255.255.255 to something else.
Any help? I am using an old laptop using Win 7 the player has HiJack on it.
Thanks!
#374709 - 05/08/2025 08:14 Re: Unable to connect Using Ethernet cable [Re: Ladmo]
You'll need to connect the player to a network hub/switch -- there are ways to get it working connected directly to a PC, but it's a bit more complicated.
Assuming the player's configured for DHCP, and you've got a DHCP server (you probably do -- your router should do it), it should just work at that point.
If the player's not configured for DHCP, you'll need to connect over serial or USB to change the configuration.
For more information, start here: https://riocar.org/FAQ/6/248.html#248
#374710 - 05/08/2025 15:09 Re: Unable to connect Using Ethernet cable [Re: Ladmo]
Ladmo
Loc: Oklahoma
If I plug the player into a switch, would I need to do it with a crossover cable or a straight through cable?
Also, what are the settings on the connection screen of Emplode if I try to connect through a switch? I am trying to remember/figure all this out from many years ago, and I never was very good at it even then, so I thank you for the help!!
#374713 - 05/08/2025 20:04 Re: Unable to connect Using Ethernet cable [Re: Ladmo]
Any modern switch from the past decade will work fine using either kind of cable: regular or "crossover". This is called "auto MDX".
#374714 - 05/08/2025 20:22 Re: Unable to connect Using Ethernet cable [Re: Ladmo]
Ladmo
Loc: Oklahoma
I was going to re-install Emplode, but I cannot find any except for an older version of it like 1.x upgrade. Is there a more current version on line somewhere? I searched the FAQ's and cannot find it, and the download section is not available anymore.
#374715 - 05/08/2025 21:12 Re: Unable to connect Using Ethernet cable [Re: Ladmo]
There are two "current" versions of emplode:
car-emplode-v2.00.zip for use with the v2 firmware, and..
car-emplode-v2.10-trunk.zip for use with v3alpha.
Try a search for those; they're probably here somewhere.
#374716 - 05/08/2025 21:14 Re: Unable to connect Using Ethernet cable [Re: Ladmo]
Nevermind. You can get either version of emplode from here for a limited time: https://rtr.ca/t/
#374718 - 06/08/2025 03:26 Re: Unable to connect Using Ethernet cable [Re: mlord]
Ladmo
Loc: Oklahoma
Thanks much Mark! I did search the best I could but could not locate it.
Awesome.Thanks again!
#374757 - Yesterday at 18:57 Re: Unable to connect Using Ethernet cable [Re: Ladmo]
suomi35
Loc: Los Angeles, CA
I was hoping this thread would be about resurrecting players with dead NICs, as I have 2 crazy
Glad you got sorted though Ladmo!
-Jason
#374758 - Today at 01:08 Re: Unable to connect Using Ethernet cable [Re: suomi35]
Yeah, I never did investigate that issue -- only happened once here I think, long long ago. Might end up being something simple, like the cs4231a bug was: https://empegbbs.com/ubbthreads.php/ubb/showflat/Number/306984
