I've never done this before, but I have a few things to offer up:
1) If you do this, don't use a program like "ghost" or "partition magic" to perform the transfer from one drive to another. One user did this, and the starting sectors of the partitions ended up in places that the Empeg software didn't expect them to be. It's better to use Empeg's tools or the linux software on the Empeg to get the job done.
2) Why would you want to ditch the 4gb drive? What would you do with it if you removed it? Do you have a laptop waiting for it or something? I'd keep the 4 and just add the 12 for a total of 16.
3) Part of the process of installing my second drive involved installing the first drive as if it were the only drive in the unit. I fully formatted it and installed a full copy of the 10a software onto it. It's a fully bootable drive right now, even though it's currently being used as the secondary drive. It was ridiculously easy, and I didn't even use the Linux command-line to do it. I'm guessing that you'd want to do the same thing, and then, using the developer image, copy the necessary song and database files from HDA to HDC. A relatively simple process, I'd bet, if you know what folders to copy (Mike will probably jump in here and fill you in).
So how did I get my second drive formatted without resorting to the Linux command-line? I've been meaning to report this on the BBS, but forgot. So I'll talk about it here.
Mike Crowe at Empeg has an image file that allows you to format a newly-installed disk. It's what they use internally at Empeg to format new drives. When I requested it, he sent me the file with some instructions. It worked perfectly, but it's not one of those things that he's ready to make publicly available because it has the capability of wiping out the existing drive if you don't remove it first.
Here's how it worked for me:
- I made sure that I had a working terminal program that could connect to the Empeg and communicate via the serial port. Part of the procedure involved watching messages scroll by in the terminal window, and I needed to be ready for it.
- Using the instructions at dmoore.com, I opened the player and removed the first disk drive (which was connected to the first IDE port). I unplugged it from the IDE port and set it in a safe place. This is the critical step that makes sure I won't format my original drive.
- I connected the second (new) drive to the first IDE connector that the first drive had been previously plugged into. At this point, only the new drive is plugged into the Empeg.
- I opened up the Empeg Upgrade Tool and fed it Mike's disk formatter upgrade file. This installs a special kernel that will immediately begin formatting the drive once it's done installing.
- After the Upgrade installed, the Empeg rebooted and began formatting its disk. I ran my terminal program to watch the text messages scroll by, reporting on the progress.
- When the formatting was done, the text messages indicated that it was running a hard disk stress-test in a continuous loop. I let that run for a while, and when I was satisified, I rebooted the Empeg.
- With the new disk drive still connected to the first IDE port, I installed the consumer 10a image. Now the disk drive is a fully bootable disk drive with the 10a image on it, but no songs yet.
- I moved the new drive to the second IDE connector, re-installed the first drive and re-assembled the unit, using the instructions at dmoore.com. Now there are two fully bootable disk drives in the unit, one of them full of my songs, and the other one with no songs. The Empeg boots and detects both drives, and Emplode shows the new capacity.
That's all I needed to do since I intended to keep using both drives. But to make the second drive the first drive, it would be the same procedure plus adding these steps at the end:
- Install the Developer 10a image to the Empeg.
- Connect to the Empeg with a terminal program.
- Q to get the shell prompt, RWM to mount the drives read-write.
- Copy the necessary song and database files to the new hard disk (Mike, fill in the details here, please?).
- Remove the first drive, and move the new drive to the first IDE connector. The unit might say "rebuilding music databases" or something for a while. After that, it's done.
I'm not certain that the playlists will transfer properly to the new drive. Mike, would that procedure also get the playlists properly transferred? Is this about the right procedure?
Tony FabrisEmpeg #144
