My empeg locked up this morning on a song at the very begining and now it wont respond after boot strap.
I ran Hyper term - it appears everything loads up fine...
starts player and hangs right there. I reloaded 1.03 successfully and no luck.
I then ran the Diag "CTRL-T" from hyperterm....
All passed ok.
I checked the suspect original song on my PC and it is ok.
i suppose it's possible that this song is corrupt on my player and causing the lockup?
The question is how do i find this bad tune to delete it?? .... or change the player so it does not try to keep playing the same song at bootup as to avoid the lockup and use emplode to remove it?
My Log...........
_________________________________________________
ÿIf there is anyone present who wants to upgrade the flash, let them speak now,
e000 v1.03
Copying kernel...
Calling linux kernel...
Uncompressing Linux................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg43 (mac@aphex.internal.empeg.com) (gcc versi
on 2.95.2 19991024 (release)) #213 Sat Jun 23 16:35:13 BST 2001
empeg-car player (hardware revision 7, serial number 80000516)
Command line: mem=12m temp=37
Memory: 11008k/12M available (960k code, 20k reserved, 292k data, 8k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004600).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DARA-212000, ATA DISK drive
hda: IBM-DARA-212000, 11513MB w/418kB Cache, CHS=23392/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:02:0
4
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...okay
Freeing unused kernel memory: 8k initI see this is a developer image!
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting
player
empeg-car 1.03.
After about 1 miniute or two it drops to the bash prompt
resume log........
Restored terminal settings
Player exited normally: 1
Starting bash.
empeg:/empeg/bin#
__________________________________END LOG________
Anyone have any Ideas????
Thanks!!
12Gb MKII 080000516 Blue
20Gb MKII 010101303 Green
20Gb MKII 090001020 Green
30Gb MKII 10101980 Blue
