#43123 - 21/10/2001 18:55 newbie questions - playlist organization
jlira
ok more questions. i read the docs and faqs and just need a human to interpret a bit
here is my starter playlist, after the first hundred random songs:
questions:
1. am i correct in assuming all the songs in subfolders will be inherited into parent folders?
2. what should i do with a subfolder that belongs in two places - i couldn't figure out a way to link it. should i just copy it? and remember to update both every time i update one?
a couple emplode questions:
is there a way to "undo" a single change? i had made 50 small corrections when i accidentally erased an artist, and i couldn't remember the artist name. am i correct in assuming my choices were either to lose all 50 changes and revert, or just live with the missing artist?
and if i have lets say 500 songs uploaded, and scattered among playlists, and i upload 500 more songs, how do i tell which 500 are NOT already in playlists?
another question - what are bookmarks really used for? i couldn't figure out what purpose they serve.
and lastly, can someone give me "scripts" of how you deal with the following normal use cases:
1. you need more bass (do you have to go to sound/eq/select/new/then manually turn up some lower tones)
2. you want to listen to all your rap stuff except 2 songs (do you have to manually create a new playlist song by song?)
3. you want to listen to all your bach and beethoven (do you have to manually create a new playlist with each song you want)?
sorry for the dumb questions - if you can't tell, i am struggling with the UI a bit. still used to the "select disc/track" paradigm i guess :)
joe
P.S. please don't criticize my choice in music - this was a random bunch of files i uploaded to help me create a scalable info architecture :)
30102792, 10 GB, Blue
#43124 - 22/10/2001 02:41 Re: newbie questions - playlist organization [Re: jlira]
Happy Birthday bonzi
Yes.
Copying a folder (or song) is linking. If you have a playlist in two parent playlists, change in one means change in others, too. No space is wasted.
Generally, you will upload by dropping songs into playlists. If you don't, but drop them in top level (a new option in 2.0), then search "refs=0" will list all those not referenced in any playlist.
To remeber the current playing set (dynamic playlist) and position within it, so that you can return to it after listening to something else.
Yes. Better yet, as you have more EQ presets than you are likely to ever need, prepare 'flat' preset, 'more bass' one, 'brighter' one etc, and just switch among them as needed. We have been promissed 'consumer' controls ('bass', 'trebble' etc), but they are not here yet. Also, there is a long standing wishlist item of asigning an EQ preset to a song or playlist (for badly produced albums).
You can Wendy-filter out those you don't want (Wendy fileters are adequately described in TFRN (release notes)).
If you do that often, create a new playlist and copy JSB and LvB playlists into it. If this is sporadic, select one for listsning and use search by playlist function in append mode to add another.
HTH
Dragi "Bonzi" Raos
Zagreb, Croatia
