#43223 - 22/10/2001 05:49
Sound through USB?
Loc: Copenhagen SW, Denmark
(OK, this may be to "high" a wish, but I'd love it)
The possibility of having audio-out through the USB cable,
so that I could just plug the empeg into my laptop at work, and play music through the laptop-speakers. I guess this could be done with an extra cable, but... this is a wish list.
An even higher wish would be the possibility of powering the empeg player through USB, but I guess that would require hardware... and I don't know how much current my laptop will supply... (maybe I should look it up in the standard)
MArius (Escort Cab + Mark II)
#43224 - 22/10/2001 06:33
Re: Sound through USB?
[Re: jane]
What SW do you plan to use on platop side to play music that 'came through USB'? Do you have any particular program and/or protocol in mind?
I don't think USB can supply at least 1A@12V (IIRC) needed by empeg, probably more during disk spin-up.
Dragi "Bonzi" Raos
Zagreb, Croatia
Dragi "Bonzi" Raos
Q#5196
MkII #080000376, 18GB green
MkIIa #040103247, 60GB blue
#43225 - 22/10/2001 06:36
[Re: bonzi]
The USB standard contains a protocol for sending audio over
USB. I don't know if the Linux USB drivers support this, though. I don't know what sort of PC drivers are needed either...
My slow memory tries to tell me that the minimal requirement for a USB host is to supply 0.5A... but I'm not sure of this. I've got the USB standard at home, I'll have a look.
Marius (Escort Cab + Mark II)
#43226 - 22/10/2001 06:41
[Re: jane]
So, we might be closer than I thought. Still, no cigar, I am affraid  .
I admit, though, that it would be nice... Do check that standard, just in case. Dragi "Bonzi" Raos
Zagreb, Croatia
Dragi "Bonzi" Raos
Q#5196
#43227 - 22/10/2001 07:06
[Re: bonzi]
If only there were some way of reading music files back from the player, one could write a Winamp plugin...
#43228 - 22/10/2001 07:10
[Re: peter]
Well, now we are closer, since we do have a backup utility that reads files through USB, don't we?
Dragi "Bonzi" Raos
Zagreb, Croatia
Dragi "Bonzi" Raos
Q#5196
#43229 - 23/10/2001 09:42
[Re: jane]
The Linux USB support does allow USB speakers to be plugged in and used. How to reverse this to the laptop, I'm not sure.
With the power requirements, I believe the empeg needs 1A max, due to the drive spinup. The biggest problem I see is trying to connect the power from USB over to the empeg's power circuitry.
The other issue on a laptop is that most don't provide the maximum power to the bus unless the laptop is plugged into AC.
This is all probably possible, but not worth the work.
