#51247 - 24/12/2001 12:39 Problem after syncing with 2.0b7
jbauer
Loc: San Francisco, CA
Every time I sync my player, everything seems to go well until I get to the "Retrieving database..." part. Then, it hangs mid-read. I have to stop the application from Windows Task Manager...
Anyone have any ideas?
- Jon
#51248 - 24/12/2001 12:57 Re: Problem after syncing with 2.0b7 [Re: jbauer]
bmiller
Loc: Sacramento, CA, USA
Are you pushing buttons on your front panel when emplode is reporting this? It looks like this is now a background application, allowing the player to restart but doesn't give enough CPU for panel button executes.
When you push a button, CPU time is split which cause the database retrieval to eventually time out.
If you just let it go until it's done without trying to push anything, it seems to finish reliably.
Does this differ from your findings?
#51249 - 24/12/2001 13:01 Re: Problem after syncing with 2.0b7 [Re: bmiller]
jbauer
When this happens, and it happens every time now, I don't touch a thing. No front panel on the empeg buttons or anything within emplode...
- Jon
#51250 - 24/12/2001 13:16 Re: Problem after syncing with 2.0b7 [Re: jbauer]
beaker
Loc: England
Mine did this on the first sync after upgrading. It's been OK since.
#51251 - 24/12/2001 17:59 Re: Problem after syncing with 2.0b7 [Re: jbauer]
I got the same behavior two times so far. I've synchronized more or less 10 times so far.
#51252 - 24/12/2001 18:46 Re: Problem after syncing with 2.0b7 [Re: jbauer]
TommyE
Loc: NORWAY
The same thing happens to me when in ' restaring player'.
This is on an MKI
I haven't had any luck with 2.0 at all on my XP machine, so I must try to use Win98
again to see if this works.
TommyE
