#60152 - 17/01/2002 07:21 Help! I blew the memory fuse!
Scorp1us
So I was installing this thing. I only need 3 wires - or so I think. Ignition sense (Orange) Memory (Yellow) and Ground (Black) I attached the ground to the metal of the car, the Yellow to my headunit's yellow (whichis also labeled "memory") and the ignition sense to a red whire that get 12v when the key is in "accessory" or "on" position.
What I did was this: After hooking it up and testing it unmounted, I put my dahs back together. I turned to acc'y mode, everything starts up, then I turn it off I waited about 1 second and turned it back on again. The blue light faded in for a second and then nothing... I inspected everything (all connections were good) and found the fuse had blown. Is there something I did wrong? Do empegs have problems with fast turn-on -> turn-off -> turn ons?
Many thanks in advance!
#60153 - 17/01/2002 12:22 Re: Help! I blew the memory fuse! [Re: Scorp1us]
Scorp1us
Well I got a new fuse, but I'm not going to try a quick turn off-on again.
Everything is kosher now.
#60154 - 17/01/2002 12:26 Re: Help! I blew the memory fuse! [Re: Scorp1us]
loren
I'm not sure what the problem was, but as far as i know, there haven't been any reported issues with quick turn on and offs.
|| loren ||
