#63250 - 25/01/2002 18:42 Power Supply - 19 VDC OK?
joe187
Loc: Massachusetts
I have a WinBook PS that I'd like to use as a second PS for my empeg. It is listed at 19volts DC. I know the Empeg spec says 6 to 18, but is 1 little volt extra going to void my warranty and/or cause any damage? Or will the songs just play faster ?
MkIIA 60 GB Smoke MkIIA 120 GB Blue
#63251 - 25/01/2002 18:45 Re: Power Supply - 19 VDC OK? [Re: joe187]
Terminator
Loc: Dallas, TX
For what its worth, you can get power supplies that are in spec for 5 or 6 dollars.
#63252 - 26/01/2002 00:25 Re: Power Supply - 19 VDC OK? [Re: joe187]
muzza
I believe the max power rating is 16v DC 1A. Says so on my lable
#63253 - 27/01/2002 08:19 Re: Power Supply - 19 VDC OK? [Re: joe187]
It should work ok; things start to get dodgy above about 20v.
The voltage doesn't affect the speed of the unit!
#63254 - 27/01/2002 10:29 Re: Power Supply - 19 VDC OK? [Re: altman]
joe187
Loc: Massachusetts
Thanks Hugo - I was only kidding about the songs playing faster. :-)
#63255 - 27/01/2002 15:30 Re: Power Supply - 19 VDC OK? [Re: altman]
muzza
would it get hotter faster?
#63256 - 27/01/2002 18:21 Re: Power Supply - 19 VDC OK? [Re: muzza]
Heat shouldn't be an issue. The main PSUs in the empeg are switch-mode, and so generally run totally cool anyway (they're 90-95% efficient) - there are a couple of linear PSUs for analogue circuitry, but these are very low current and so don't dissipate a lot of heat.
