#88468 - 17/04/2002 05:58 Anyway to show an .html to a specific IP?
SE_Sport_Driver
I have someone who keeps posting nasty messages on my guestbook for my site. I had blocked the guy's IP address because he is dumb enough to do it from his home w. a static IP. I also blocked his work computers becuase they share an IP range. Is there some javascript that would let me send only him to a certain page I made saying something?
#88469 - 17/04/2002 06:10 Re: Anyway to show an .html to a specific IP? [Re: SE_Sport_Driver]
David
Loc: Cambridge
As far as I am aware, you can't get the IP address in JavaScript.
You can use an SSI to insert the IP into the HTML then use Javascript to compare it and display a message dialog.
However, since the guestbook must use some sort of server-side script, you should be able to hack something into the code fairly easily.
Edited by David (17/04/2002 06:16)
#88470 - 17/04/2002 09:13 Re: Anyway to show an .html to a specific IP? [Re: David]
bmiller
Loc: Sacramento, CA, USA
I agree, you would definitely do something server side to display the message only if the requestor IP is the one you are looking for.
#88471 - 17/04/2002 09:28 Re: Anyway to show an .html to a specific IP? [Re: SE_Sport_Driver]
genixia
Do you have PHP installed?
#88472 - 17/04/2002 10:27 Re: Anyway to show an .html to a specific IP? [Re: SE_Sport_Driver]
SE_Sport_Driver
I will have to check... it is through www.DreamBook.com
