#88962 - 18/04/2002 12:27
Re: After Windoze 98 crash, all songs on Empeg GON
[Re: CurlyKicker]
If you are on 2.0b11, that is fine. Hijack was the add on I was thinking of.
Have you contacted support yet? I am running out of ideas (that will save your data). You may also want to drop a note to Mark Lord. If anyone can help diagnose fs problems...
#88963 - 18/04/2002 12:28
[Re: pgrzelak]
Loc: Lochcarron and Edinburgh
Incorrect device... (thinks)
I don't see how it could happen, but is /dev/ corrupted? What does "ls -l /dev/hda*" give?
I get
empeg:/empeg/bin# ls -l /dev/hda*
brw------- 1 0 0 3, 0 Apr 18 1999 /dev/hda
brw------- 1 0 0 3, 1 Apr 18 1999 /dev/hda1
brw------- 1 0 0 3, 2 Apr 18 1999 /dev/hda2
brw------- 1 0 0 3, 3 Apr 18 1999 /dev/hda3
brw------- 1 0 0 3, 4 Apr 18 1999 /dev/hda4
brw------- 1 0 0 3, 5 Apr 18 1999 /dev/hda5
brw------- 1 0 0 3, 6 Apr 18 1999 /dev/hda6
brw------- 1 0 0 3, 7 Apr 18 1999 /dev/hda7
brw------- 1 0 0 3, 8 Apr 18 1999 /dev/hda8
brw------- 1 0 0 3, 9 Apr 18 1999 /dev/hda9
If you don't see this, then something's wrong.
EDIT: What worries me more is that the partition table has gone off into a wibbly wobbly world of its own, though again I don't see how losing the PC during a sync could cause that.
Edited by tms13 (18/04/2002 12:30)
#88964 - 18/04/2002 12:30
[Re: pgrzelak]
Loc: Orange County, CA
No I haven't contacted support yet. I thought I'd give you guys a crack at it first (I know how you guys like a good challenge). I'll give M.Lord a holler and contact support in a few minutes.
#88965 - 18/04/2002 12:33
[Re: tms13]
This:
empeg:/empeg/bin#
#88966 - 18/04/2002 13:05
[Re: CurlyKicker]
Can you try "fsck.ext2 -b 32768 /dev/hda4" ?
I thought that mke2fs defaulted to 4k blocks. It certainly doesn't make sense for 1k blocks to be used for music partitions anyway. If anything they're going to be larger blocksizes.
#88967 - 18/04/2002 13:09
[Re: genixia]
Hopefully you've done it Genixia. Here's the result:
empeg:/empeg/bin# fsck.ext2 -b 32768 /dev/hda4
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
hda4 is mounted.
/dev/hda4 was not cleanly unmounted, check forced.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Entry 'database' in /var (4097) has deleted/unused inode 4098. Clear<y>?
should I enter "Y"?
#88968 - 18/04/2002 13:17
[Re: CurlyKicker]
Personally, I would hit 'y', but I'm a risk taker. The fact that I've never seen e2fsck get anything wrong helps too...
IIRC, I seem to remember reading that the /var parition could be wiped at will - and that anything important gets recreated. In particular, the database gets rebuilt everytime you sync the empeg anyway. But you might want to check this information first.
Anyone else want to chime in?
#88971 - 18/04/2002 14:00
[Re: CurlyKicker]
Well, removing the inode entry is equivalent to deleting it anyway, which you've already tried..so I say go for it with that one, and also tags and playlist.
Ultimately as I understand it, e2fsck is telling you that you a have an inode pointing to a physically non-existant file. Whether the inode is there or not doesn't really matter at this point - the file is missing.
#88972 - 18/04/2002 14:11
[Re: genixia]
Ok I went for it. Here's the result:
hda4 is mounted.
Entry 'database' in /var (4097) has deleted/unused inode 4098. Clear<y>? yes
Entry 'playlists' in /var (4097) has deleted/unused inode 4099. Clear<y>? yes
Entry 'tags' in /var (4097) has deleted/unused inode 4100. Clear<y>? yes
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
Block bitmap differences: -3112963 -3112964 -3115019 -3115020 -3118394 -3118395
-3118396 -3118397 -3118398 -3118399 -3172820 -3172821 -3172822 -3172823 -317282
4 -3172825 -3172826 -3172827 -3172828 -3172829 -3172830 -3172831 -3172832 -31728
33 -3172834 -3172835 -3172836 -3172837 -3172838 -3172839 -3172840 -3172841 -3172
842 -3172843 -3172844 -3172845 -3172846 -3172847 -3172848 -3172849 -3172850 -317
2851 -3172852 -3172853 -3172854 -3172855 -3172856 -3172857 -3172858 -3172859 -31
72860 -3172861 -3172862 -3172863 -3172864 -3172865 -3172868 -3172869 -3172876
Fix<y>? yes
Free blocks count wrong for group #44 (15293, counted=0).
Fix<y>? yes
Free blocks count wrong for group #47 (2, counted=0).
Fix<y>? yes
Free blocks count wrong for group #48 (8553, counted=0).
Fix<y>? yes
Free blocks count wrong for group #49 (13701, counted=0).
Fix<y>? yes
Free blocks count wrong for group #51 (4764, counted=0).
Fix<y>? yes
Free blocks count wrong for group #65 (1, counted=0).
Fix<y>? yes
Free blocks count wrong for group #69 (1, counted=0).
Fix<y>? yes
Free blocks count wrong for group #71 (1, counted=0).
Fix<y>? yes
Free blocks count wrong for group #88 (1, counted=0).
Fix<y>? yes
Free blocks count wrong for group #94 (24949, counted=0).
Fix<y>? yes
Free blocks count wrong for group #95 (32734, counted=10).
Fix<y>? yes
Free blocks count wrong for group #96 (32734, counted=5679).
Fix<y>? yes
Free blocks count wrong (1880885, counted=1753840).
Fix<y>? yes
Inode bitmap differences: -4098 -4099 -4100
Fix<y>? yes
Free inodes count wrong for group #3 (36, counted=0).
Fix<y>? yes
Free inodes count wrong for group #4 (1019, counted=1022).
Fix<y>? yes
Free inodes count wrong for group #9 (935, counted=878).
Fix<y>? yes
Free inodes count wrong (149435, counted=149345).
Fix<y>? yes
/dev/hda4: ***** FILE SYSTEM WAS MODIFIED *****
/dev/hda4: 3231/152576 files (5.9% non-contiguous), 3109130/4862970 blocks
Now what?
#88973 - 18/04/2002 14:17
[Re: CurlyKicker]
Well Genixia WINS!!! Great job! Everything back to normal. Everything was rebuilt and I did a synch with Emplode which worked perfectly. A big thanks to everyone that helped out, especially to you Genixia.
#88974 - 18/04/2002 14:26
[Re: CurlyKicker]
I think that the credit should go to the designers and coders of ext2fs and it's related tools.
#88975 - 18/04/2002 14:33
[Re: genixia]
Question remains: What was the cause and how to prevent it from happening again.
Oversized config.ini? Lack of jiffies-fix in the kernel? What?
#88976 - 18/04/2002 14:36
I hope it was the jiffies so that we could get the latest alpha sent to beta! ![](/images/icons/smile.gif) Just like the cut&paste thing got us beta11 real quick!
#88977 - 18/04/2002 14:41
How can I check to see if the Config.ini is "oversized"?
#88978 - 18/04/2002 14:44
Naah. My theory:
The drives were put into r/w by emplode. Win98 then crashed, leaving the drives in r/w. When win98 gets rebooted, emplode cannot connect to the empeg because the empeg already has a sync session in progress. empeg gets powered-down with the discs still mounted r/w, and the corruption occurs in the main superblock, necessitating the use of an alternative superblock to complete e2fsck.
This is probably worth FAQing. ie, the part that if you see a bad superblock message that causes fsck to fail then to specify -b 32768. Although input from the empeg guys should probably be sought.
#88979 - 18/04/2002 14:50
[Re: genixia]
If this bad superblock thing is true, would the instructions be something that can be added logically to the existing FAQ entry on FSCK? Could I get an accurate syntax and a consensus on the proper directions?
#88980 - 18/04/2002 15:50
[Re: CurlyKicker]
No one answered your question about the config.ini. Here is the FAQ entry on it. Basically, it is only a concern if you have played with the "favorite visuals" feature in emplode...
#88981 - 18/04/2002 16:20
[Re: SE_Sport_Driver]
Thanks. I failed to say that after all was fixed, the Visual Favorites did get deleted and I had to reprogram it. Now come to think of it I might have synced more than once in a single session, something that I forgot not to do with v2.0b11. When's the next beta coming out? ![](/images/icons/smile.gif) j/k
#88982 - 18/04/2002 17:32
Well, I'm kinda late tuning in (might have saved some time, but igenixia figured it out, well done!), but for the FAQ just simply say,
If you see this:
fsck.ext2: Bad magic number in super-block while trying to open /dev/hda4
then do this:
fsck.ext2 -fay -b 32768 /dev/hda4 Cheers
EDIT: added -fay to the above
Edited by mlord (18/04/2002 17:33)
#88983 - 18/04/2002 17:47
Do the drives need to be mounted read-write, read-only...?
After it's done... Do I have to set it back...?
#88984 - 18/04/2002 18:13
Drives should NOT be mounted read-write (they won't be, either, unless the user mounted them him/her self). Read-only is okay; or not mounted at all is good, too.
Afterwards, just reboot the player (cycle the power).
#88985 - 19/04/2002 02:35
[Re: genixia]
That would be my guess too.
Interestingly, there is a failsafe in the player that can sometimes stop this happening. If the PC or Emplode crashes, but the player does not, the player eventually (2 minutes later) decides that Emplode isn't coming back, and remounts the discs read-only by itself.
So the message is (and I admit here it's our fault for not getting the message out more), if your PC has crashed while the Empeg has the "synchronising" screen up, wait for the sychronising screen to go away before powering off the Empeg. Any playlists you were editing will probably still be lost, but at least your filesystem will not get borked.
#88986 - 19/04/2002 02:39
Indeed. And the rebooting bit is important: you can easily scrag your filesystem if you mount it read-only for fsck, then fsck fixes something, then you remount it read-write and do stuff to it. So always either (a) unmount the filesystem to fsck it, or (b) reboot afterwards if fsck made any modifications. For music partitions (a) is easier, but obviously for the root partition (b) is the only way.
Failure to do either (a) or (b) was the bug in the only known alpha release of the player ever to have hosed someone's music partition.
#88987 - 19/04/2002 10:20
[Re: peter]
Okay, additions to FAQ entry made, per the comments in this thread.
#88988 - 02/05/2002 14:45
Well it happened again today. Recieved the same error as the one mentioned in the first post. Windows did not crash this time and I have Hijack installed. Here's the Hyper Terminal login info:
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005d80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-220, ATA DISK drive
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:05:a
d
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...ԕjչѕɽсɁѕɕ)5chan
ge_root: old root has d_count=1
Mounting proc
EXT2-fs error (device ide0(3,4)): ext2_check_descriptors: Block bitmap for group
0 not in group (block 1396520500)!
Remounting filesystem read-only
EXT2-fs: group descriptors corrupted !
Tried to mount /dev/hda4 as ext2 but got error 22
No primary hard disk
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComplStarti
ng player
player.cpp : 385:empeg-car 2.00-beta11 2002/02/08.
! tags.cpp : 61:Failed to open tags (0xc0041002).
Prolux 4 empeg car - 2.1434 Feb 7 2002
Vcb: 0x4086d000
q
Restored terminal settings
Player exited normally: 0
Starting bash.
empeg:/empeg/bin# e2fsck -b 8193 /dev/hda4
bash: e2fsck: command not found
empeg:/empeg/bin# fsck.ext2 -b 8193 /dev/hda4
Went ahead and typed "fsck.ext2 -b 32768 /dev/hda4" to fix it. Works fine now but I see these errors in the Hyper Terminal:
..."Partition check:
hda:hda: set_geom(16383,16,63)
Press Ctrl-A to enter pump...ԕjչѕɽсɁѕɕ)5 chan
Mounting proc
Press 'q' now to go into development mode. You Have Zero Seconds To ComStarting
player
Any thoughts?
#88989 - 02/05/2002 14:52
[Re: CurlyKicker]
The first yellow error is because it first tries to mount it as a reiser filesystem (journalling - inherited from some other product or if it was planned but not used)
It's benign as the player falls back and mounts it as an ext2 filesystem instead.
The second error is because you have only one drive. It always tries to mount the music partition of the second drive, even when it's not there - also benign.
#88990 - 02/05/2002 14:56
[Re: mtempsch]
Oh well ok. Thanks.
But I am concerned about this happening a second time within such a short period of time and the fact that no one else seems to have this reoccuring problem. Perhaps it's time to contact support.
