#89232 - 18/04/2002 23:53
Notepad
A quick question about Notepad (Windows).
Is there a way to make it always view "all files" in the open file menu? I use Notepad for HTML all the time, and it's annoying to have to choose "all files" every time.
#89233 - 19/04/2002 06:30
Re: Notepad
Can't help, but I'm an old school Notepad user too, so let me know what you find.
![](http://empeg.comms.net/files/87326-notepad2.gif)
#89234 - 19/04/2002 08:22
Re: Notepad
[Re: SE_Sport_Driver]
Haha! Thanks for the image, I'm gonna use that
#89235 - 19/04/2002 09:22
Re: Notepad
If you've got a hex editor then you can patch it to default to *.* instead of *.txt
If you've got the XP version of Notepad which is 66048 bytes:
Change byte 7C0 to 2A from 74
Change byte 7C2 to 00 from 78
Change byte 7C4 to 00 from 74
The text in the combo box is wrong now but it's only a cosmetic thing
- Trevor
#89236 - 19/04/2002 09:27
Re: Notepad
Yes.
Replace it with UltraEdit.
#89237 - 19/04/2002 09:36
Re: Notepad
Or TextPad, which I prefer.
Woohoo, UltraEdit vs. TextPad religious argument. It's been a while ![](/images/icons/wink.gif) .
#89238 - 19/04/2002 09:38
Re: Notepad
[Re: Roger]
Can the Unix folks participate too? Does Textpad team up with vi or emacs?
Edit:
bla, s/Note/Text/
Edited by mtempsch (19/04/2002 09:39)
#89239 - 19/04/2002 10:26
Re: Notepad
[Re: mtempsch]
At empeg, some people use TextPad and some squirrelly rsh scripts, specifically to avoid having to run emacs or vi. The rest of us run emacs of one flavour or another.
Personally, I'm an xemacs guy, unless it's a really quick edit, in which case, 'vi' is easier to type ![](/images/icons/wink.gif) .
How's that for fence-sitting?
#89240 - 19/04/2002 11:00
Re: Notepad
[Re: Roger]
Loc: Georgetown, TX USA
Hey! Yer sittin' on my spot of the fence!
Dave Clark
Georgetown, Texas
MK2A 42Gb - AnoFace - Smoke Lens - Dead Tuner - Sirius Radio on AUX
#89242 - 19/04/2002 11:53
Re: Notepad
[Re: Roger]
Loc: San Diego, CA, USA
I'll put my vote in for TextPad.
__________________
Scott
MKIIa 10GB - 2.0b11 w/Hijack
MKIIa 60GB - 2.0 final w/Hijack
#89243 - 19/04/2002 12:18
Re: Notepad
[Re: svferris]
Im gonna send up the flag for notetab which has to win cos its an excuse to visit a website with a .ch domain!
(and it's a pretty good text editor)
#89244 - 19/04/2002 12:52
Re: Notepad
[Re: mtempsch]
I can't believe you started a text editor war without me!
vi all the way! Emacs csucks!
#89245 - 19/04/2002 13:05
Re: Notepad
[Re: loren]
Loren has this one right. It's all about pico. Nothing fancy. It won't give you nightmares of parenthesis from trying to implement your own mail reader in emacs.... It is, however, twice as long to type as vi, but still a letter shorter than emacs. All i want is the nifty color-coding that emacs can do for code, but I live wihtout that.
#89246 - 19/04/2002 13:11
Re: Notepad
[Re: Roger]
Loc: Seattle, WA, U.S.A.
Years ago I used Brief, ut then got completely hooked on the DOS version of MultiEdit . In the DOS world it was, for all intents and purposes, its own little IDE. Then Windows came along and MultiEdit went thataway.
One feature it had and that I loved was the ability to collapse a file (for quick navigation) using a function key based on user-defined customs strings. So, in function headers, I'd add a redundant function statement behind a custom comment string like "#*# function" then could hit <F4> and the file would collapse to just those comments. Move the cursor to the desired function, then hit <F4> to expand.
Maybe this is now a really common feature. Anyhow, can anyone recommend a Linux-capable editor/IDE that includes syntax highlighting for C, C++ and others and that includes a "collapse" capability (without having to build it myself in Emacs!).
Thanks!
Jim
#89247 - 19/04/2002 13:17
Re: Notepad
[Re: jimhogan]
Anyhow, can anyone recommend a Linux-capable editor/IDE that includes syntax highlighting for C, C++ and others and that includes a "collapse" capability (without having to build it myself in Emacs!). Vim!
#89248 - 19/04/2002 13:37
Re: Notepad
[Re: jimhogan]
The IDE in Microsoft's ".NET" development environment does collapsible functions automatically, without even needing to change the syntax.
/me ducks, covers head, and runs out of the room.
#89249 - 19/04/2002 14:36
Re: Notepad
Well, fair enough. I didn't make any stipulation about ease of use! I run Vim, but perhaps I wasn't using the right nomenclature to find its version of a collapse feature.
Is this an example what you mean?:
FOLDTEXT *fold-foldtext*
'foldtext' is a string option that specifies an expression. This expression is evaluated to obtain the text displayed for a closed fold. Example:
:set foldtext=v:folddashes.substitute(getline(v:foldstart),'/\\*\\\|\\*/\\\|{{{\\d\\=','','g')
This shows the first line of the fold, with "/*", "*/" and "{{{" removed.
Note the use of backslashes to avoid some characters to be interpreted by the ":set" command. It's simpler to define a function and call that:
:set foldtext=MyFoldText()
:function MyFoldText()
: let line = getline(v:foldstart)
: let sub = substitute(line, '/\*\|\*/\|{{{\d\=', '', 'g')
: return v:folddashes . sub
:endfunction
Evaluating 'foldtext' is done in the |sandbox|. The current window is set to the window that displays the line. Errors are ignored.
Of have I perhaps headed down the wrong Vim alley?
Jim
#89250 - 19/04/2002 14:45
Re: Notepad
Now functionally, that's really what I want. It looks from this that the Windows version of MultiEdit now does that via syntax instead of my old kludge (but no Linux version...).
Don't worry, Tony, someone will read your message who *would* touch .NET with a 10-foot insulated pole with rubber boots on!
Jim
#89251 - 19/04/2002 14:47
Re: Notepad
[Re: jimhogan]
Yup. It's not difficult to use, it just doesn't understand every language's syntax, so you have to place markers specifically (:help fold-markers). You can also define where to fold in the same syntax file that defines coloring (:help fold-syntax), which should be more transparent, but I've not played with this yet.
#89252 - 19/04/2002 14:55
Re: Notepad
Thanks. I'll take some time and give it a thought.
Geez, come to think of it, when I went to the grocery store earlier today, there was a guy sitting outside with a sign that said "Will Evaluate Regular Expressions for Food" . I should run back over and see if he's still there!
Jim
#89253 - 19/04/2002 18:50
Re: Notepad
[Re: Roger]
Loc: US: CA
TextPad all the way. Been using it for years, and not about to stop now.
#89254 - 22/04/2002 03:14
Re: Notepad
[Re: ricin]
Mmm - UltraEdit under Winblows, vi under Linux, Jot under Irix.
Now what did I used to use on my Osborne cp/m box?
#89255 - 23/04/2002 23:32
Re: Notepad
[Re: frog51]
Loc: Alexandria, People's Republic ...
#89256 - 24/04/2002 00:58
Re: Notepad
[Re: pycckuu]
Loc: Cambridge
Seconded. If you're a Mac user, that is.
#89257 - 24/04/2002 13:25
Re: Notepad
[Re: David]
I use a little freeware editor called PFE
Am I the only one?
I'm with loren on pico...I never had the discipline to learn vi
