The DSP has a dynamic range compression option, though it's not brilliant (which is why we didn't bother with it). It works, but the effect is maybe a bit too slight... it also is very fixed in how it operates.Aw, shucks.
Okay, then, have you had a look at
Rjlov's code? I haven't been able to try it out yet, although I keep wanting to. I know you're busy this week trying to actually, you know, ship an actual product and everything.
But I was just wondering what you thought of his approach and if you'd consider implementing it or something like it down the road.
In fact, while I'm on the subject, I'm in a bit of a quandary with versions. I'm at 10a (pre-buttonfix) now. I want to try the version 11 stuff that I saw in San Jose, but I also want to try rjlov's volume compressor. Rjlov's stuff is at beta 10 (not 10a), but the version 11 notes says I should have the 10a-buttonfix kernel installed before installing the version 11 player. Is there any way I can run Rjlov's v10 kernel and the version 11 player together, or does he need to compile a v11 kernel with his stuff?
