I just put together my new system, with the Xp1800 and the IwillXP333 board. After i put it all together, i turned it on and saw that it recognized the XP1800 and 1.5 ghz or so, and it picked up the 256mb of PC2700 ram. I then went into BIOS and was poking around. For whatever reason, i hit "Load Optimal Settings", and when it restarted, it showed the XP1800 to be at 1.15ghz and the memory says, "Main Memory is DDR200"
I can't figure out how to make it recognize the real settings?
There is no "Load Default Settings", just "Load Optimal" or "Load Failsafe", and with either one, i get the same result.
I've tried clearing CMOS and that doesn't work either.
anyone?
