#92692 - 09/05/2002 00:44 Help back up discs
thinfourth2
okay i want to make a set of self booting recovery discs on cd rom for my mothers computer so she can recover it to its current state instead of factory state.
Any idea how i would go about it.
As an extra challenge she has no cd writer but i have a spare network card and a laptop and a cd writer at home.
#92693 - 09/05/2002 06:39 Re: Help back up discs [Re: thinfourth2]
dcosta
Loc: Massachussetts
Best bet is to buy another hard drive,
just a (used and cheap) spare, just big enough to fit the contents of her C:\ drive.
install the new harddrive and ghost her C:\ to the new disk using ghost.
Then you can wipe the existing hard drive then repartition it using FDISK,
make 2 partitions this time on the hard drive one for C:\ and the other is D:\
You can make them whatever sizes you want,
I usually don't make C:\ any bigger than 5 GB depending on what version of windows and how big the disk is. The rest of the disk (D:\) is for user files, think of it as a separate drive lettter for "My Documents"
Now just restore the new C:\ partition from the ghost file you created on the (new) spare disk.
The beauty of this setup is that once you have the partitions in place you can "ghost" the state of C:\ to a file it creates on D:\ which is the separate partition of the same hard drive. Then at anytime you can just boot into dos from floppy and restore C:\ from any ghost file you have on D:\
HTML manual for using ghost can be found here : http://davecosta.com/software/ghostmanual.htm
__________ davecosta Hijacked 60GB MKIIa 2.0b13
#92694 - 09/05/2002 07:38 Re: Help back up discs [Re: dcosta]
blitz
Loc: Texas
I do pretty much the same thing and the the Ghost method works well. I do not make a gho image but a true clone disk. In this case, all you have to do is reset the master slave on the clone disk to master and unplug the other drive from the IDE cable and you reboot and go.
I had zero luck with the Promise Raid controllers as I could never get XP to boot from the RAID controller.
