#96956 - 01/06/2002 09:30 Network not work in car
thinfourth2
Okay here is a puzzler i have a Mk2a running 2.0b11 and hijack 266 and i have a fixed ip address on the empeg.
I have tried playing with wireless but could not get it to work in the car whic i tracked down through a process of elimination that i can't connect via ethernet when in dc mode.
When i forced AC mode through hijack everything worked fine.
Is there anything that i should check or does anone have any ideas. I have not tried with out Hijack yet but might do later on.
A second question is the aerial for a wireless hub does it have to be a tunned length or would any length of aerial work within reason. As i have an old cell phone arieal on the car dong nothing yet.
#96957 - 01/06/2002 19:01 Re: Network not work in car [Re: thinfourth2]
genixia
What type of connection are you trying? http?
Make sure that you have DC_servers=1 in the [hijack] section of your config.ini.
(Check the syntax in the FAQ...I think it's as I just typed, but I'm not 100% certain)
