Depending on where the break in your handle is located, you may be able to effect a temporary (albeit ugly) repair.
If the handle is broken like:
you could slide a piece of metal tubing over the break, perhaps beat on it a bit to mold it into a closer fit and add a bit of epoxy to the mix to hold it in place.
The handle wouldn't fold flat against the face of the player any more, but until you get a replacement handle it would do the job.
