I was gonna say pin it, as a matter of fact I'm sure I did and it was squashed in the power failure.
Anyway if the break is near one end you should clamp the ends together and drill thru the end and insert pin. Like this
########B#######
####PPPPPPPPPPPP
########B#######
B=BREAK P=HOLE/PIN
A pin diameter of .032" inserted at least .125 past the break should work.
