No I haven't, but I did use WsFTP to "delete" the database, playlists and tags and then let the player rebuild them on it's own, followed by a sync in Emplode. Wouldn't that be the same thing?
I'm running fsck again and here's what has happened so far:
empeg:/empeg/bin# ro
empeg:/empeg/bin# umount /dev/hda4
empeg:/empeg/bin# umount /dev/hdc4
empeg:/empeg/bin# swapon /swapfile
Adding Swap: 16028k swap-space (priority -1)
empeg:/empeg/bin# fsck -fay
Parallelizing fsck version 1.19 (13-Jul-2000)
empeg:/empeg/bin# fsck -fay /dev/hda4
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/
hda4 is mounted.
Pass 1: Checking inodes, blocks, and sizes
fsck -fay /dev/hdc4
swapoff /swapfile
sync
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
Block bitmap differences: -32586791 -32590110 -32590111 -32590112 -32590113 -32
590114 -32590115 -32590116 -32590117 -32590118 -32590119 -32590120 -32590121 -32
590122 -32590123 -32590124 -32590125 -32590126 -32590127 -32590128 -34926723 -34
926724 -34926725 -34926726 -34926727 -34926728 -34926729 -34926730 -34926731 -34
926732 -34926733 -34926734 -34926735 -34926736 -34926737 -34926738 -34926739 -34
926740 -34926741 -34926742 -34926743 -34926744 -34926745 -34926746 -34926747 -34
926748 -34926749 -34926750 -34926751 -34926752 -34926753 -34926754 -34926755 -34
926756 -34926757 -34926758 -34926759 -34926760 -34926761 -34926762 -34926763 -34
926764 -34926765 -34926766 -34926767 -34926768 -34926769 -34926770 -34926771 -34
926772 -34926773 -34926774 -34926775 -34926776 -34926777 -34926778 -34926779 -34
926780 -34926781 -34926782 -34926783 -34926784 -34926785 -34926786 -34926787 -34
926788 -34926789 -34926790 -34926791 -34926792 -34926793 -34926794 -34926795 -34
926796 -34926797 -34926798 -34926799 -34926800 -34926801 -34926802 -34926803
Fix? yes
Free blocks count wrong for group #3977 (0, counted=1).
Fix? yes
Free blocks count wrong for group #3978 (0, counted=19).
Fix? yes
Free blocks count wrong for group #4263 (3783, counted=3864).
Fix? yes
Free blocks count wrong (42904651, counted=42904752).
Fix? yes
Inode bitmap differences: -16578
Fix? yes
Free inodes count wrong for group #259 (59, counted=60).
Fix? yes
Free inodes count wrong (593288, counted=593289).
Fix? yes
/dev/hda4: ***** FILE SYSTEM WAS MODIFIED *****
/dev/hda4: 16439/609728 files (24.9% non-contiguous), 35139018/78043770 blocks
Bodybag - So Cal
Not a Whiner any more!!!
