Here is the hyperterminal output from in AC mode if it helps
e000 v1.04
Copying kernel...
Calling linux kernel..
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v488 (hijack@rtr.ca) (gcc version
2.95.3 20010315 (release)) #2 Fri Feb 15 10:29:26 EST 2008
Checking for extra DRAM:
c1000000: wrote ffffffff, read 00000000
empeg-car player (hardware revision 9, serial number 30103118) 16MB DRAM
Command line: mem=16m
Memory: 15000k/16M available (992k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Found custom animation at offset 0x99380
Tuner: loopback=0, ID=-1
show_message("Hijack v488 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initiali
empeg audio-in initialised, CS4231A revision a0ed, the device was in an unknown
empeg usb initialised, PDIUSBD12 id 1012ed driver
empeg state support initialised 0089/88c1 (save to d0005d00).rred, registers were:
empeg RDS driver initialisedinitialized:
empeg power-pic driver initialised sizeA1100 UART
empeg
02 11 e0 59 00 00 03 Error: a SA110
empeg single channel IDE
Pr
Probing primary interface...
Commands leading to t
ide_data_test: wrote 0x0000 read 0xff0000 read 0x0000RT
ide_data_test: wrote 0xffff read 0xff00
ide_d
CR FR SC
ide_data_test: wrote 0xaaaa read 0xaa00d/Feature_Namend cus
ide_data_test: wrote 0x55
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0c:2
Partition check: initialisedion
e
Partition check:hda5 hda6
hda: hda1 < hda5 hda6 > hda2 hda3 hda4 After command completion occurred, re
RAMDISK: ext2 filesystem found at block 0donly.isk driver initia
ER ST SC SN CL CH DH 4096
EXT2-fs warning: checktime reached, run
Mounting proc
No secondary hard disk
Starting player
Timezone: Atlantic/South_Georgia
Hijack: intercepting config.ini
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
player.cpp : 385:empeg-car 2.01 2004/07/06.
Prolux 4 empeg car - 2.1434 Jul 5 2004
Vcb: 0x4086d000
Dead temp.sensor, status=0x00
Edited by newguy1 (04/05/2008 22:33)
MIKE 80Gb RIO
