Refresh rate on LCDs is irrelevant. The reason a low refresh rate on a CRT can hurt your eyes because it flickers. It flickers because the same thing that generates the image also generates the light. The light generation source on a an LCD, though, is constant. (Well, effectively constant. The CCFLs that LCDs use for backlighting run at several hundred hertz.)
