I usually have no problems with ethernet, except when it just randomly disconnects. I read the FAQ and most of those problems are for first-time installations. I can stream music via Hijack and it will shut off and even during emplode sync's it will die. I can connect just fine but after a few modifications to the playlist I can't sync becuase the ethernet connection is gone.
The only way to make sure the empeg stays alive is if I have a dos window open and pinging the empeg's IP address.
Any ideas? Anyone else have this problem?
later,
ajay
