#137151 - 25/01/2003 13:23 Nero and DVDs
Happy Birthday Dignan
I just received my Sony DVD burner today. I've installed it and now I'm trying to use Nero to burn a DVD. The problem is, the DVD options are grayed out! There is no mention in the help file of why this could be. What do I do to get it working?
#137152 - 25/01/2003 13:25 Re: Nero and DVDs [Re: Dignan]
DeadFire
Did you check Nero's website to see if it's compatible with your DVD burner?
#137153 - 25/01/2003 13:33 Re: Nero and DVDs [Re: Dignan]
CrackersMcCheese
Its also worth getting the update from the Nero site. It should get the most current models running.
Failing that, reinstall Nero after the burner. I had this problem with a CD writer.
#137154 - 25/01/2003 13:33 Re: Nero and DVDs [Re: DeadFire]
Thanks, I didn't know they had a compatability list. Turns out I just need to update to a newer version. I'll see if this works. Thanks
