#206823 - 25/02/2004 14:20 Preventing lettering from rubbing off
burdell1
I recently replaced the window switch in my pontiac sunfire. However, the little window symbol in the old one had, for the poster, rubbed off. Is there anything I can put over it to prevent it from happening again on the "new" one? (it came from a junk yard, but it looks pretty new on the surface.)
#206824 - 25/02/2004 14:24 Re: Preventing lettering from rubbing off [Re: burdell1]
belezeebub
maybe a Few thin coats of clear coat krylon ?
______________________________________ Do not meddle in the affairs of Network Administrators, for they are subtle and quick to anger. ______________________________________ Worlds Lamest Wb Site (mine) http://home.comcast.net/~jlipchitz/
#206825 - 25/02/2004 14:29 Re: Preventing lettering from rubbing off [Re: belezeebub]
burdell1
would it retain its matte finish or would it then be glossy?
#206826 - 25/02/2004 14:30 Re: Preventing lettering from rubbing off [Re: burdell1]
genixia
You could apply a clearcoat over it. There are _many_ possibilities here - a craft-store paint sealer, some household varnishes, car bodywork clearcoat (common on e.g. modern VWs), epoxy or polyester resin etc. The list of potential clearcoats is long.
All of these will have the side effect of adding a visible gloss to the finish. This may not matter depending on the original button finish and location. You might want to test on the old one.
#206827 - 29/02/2004 14:11 Re: Preventing lettering from rubbing off [Re: genixia]
Krylon comes in both gloss and Matte finishs.
#206828 - 01/03/2004 17:49 Re: Preventing lettering from rubbing off [Re: gbeer]
trs24
<Foxworthy>Say it in Krylon!!!!</Foxworthy>
- trs
