#209856 - 19/03/2004 06:10 Question about V3.0 alpha7
DBALKUNJR
Ok, I uploaded a couple of albums to my player a couple of days ago using V3.0 alpha7 and Emplode 2.0 final. It worked out just fine. So come last night I go to add some more songs to the player again. Well, this time the player took forever to rebuild the database. So I thought that the software had frozen and unplugged the player. When I plugged it back in to power it started to rebuild the databases on the player it self with the percentages running until it finally started. After that I went and tried to synch with Emplode and it started to check disk integrity for quite some time. After about 20 minutes I just unplugged the power again since I had to get some sleep and could not monitor it overnight. So here I am the next morning and when I plugged the player into my sled in the car as expected, it starts to rebuild databases again......Fast forward I am now at work and want to try and synch with Emplode 2.0 final here at the office....Question is, is this safe to do or do I have to use the same computer as I started with. The reason I ask is because a while back I thought I read something somewhere on the BBS about how you could not stop half way through a synch and change computers.
Dave
MK2 12Gb
MK2a 60Gb
#209857 - 19/03/2004 06:17 Re: Question about V3.0 alpha7 [Re: DBALKUNJR]
crazymelki
Loc: Switzerland
crazymelki.com
#209858 - 19/03/2004 06:34 Re: Question about V3.0 alpha7 [Re: DBALKUNJR]
thinfourth2
whee do i get alpha 7 anyway
#209859 - 19/03/2004 07:11 Re: Question about V3.0 alpha7 [Re: crazymelki]
DBALKUNJR
OK, I am hooked up in Hyperterminal and it seems that it won't accept my input. I get the EXT2-fs warning and when I try to follow the commands from the FAQ on how to rectify it I get this:
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v378 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Sat Feb 21 18:05:39 EST 2004
empeg-car player (hardware revision 9, serial number 10101980)
Command line: mem=16m
Memory: 15016k/16M available (980k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005480).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-230, ATA DISK drive
hdb: IBM-DJSA-230, ATA DISK drive
hda: IBM-DJSA-230, 28615MB w/1874kB Cache, CHS=58140/16/63
hdb: IBM-DJSA-230, 28615MB w/1874kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:07:b
c
Partition check:
Timezone: /usr/share/zoneinfo
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
Timezone: /usr/share/zoneinfo/Atlantic/South_Georgia
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
player.cpp : 564:empeg-car 3.00-alpha7 2004/02/13.
! tags.cpp : 61:Failed to open tags (0xc0041002).
Prolux 4 empeg car - 2.1490 Feb 13 2004
Vcb: 0x4082c000
Restored terminal settings
Player exited normally: 0
Starting bash.
empeg:/empeg/bin# rwm
EXT2-fs warning: mounting unchecked fs, running e2fsck is recommended
ro
unmount /dev/hda4
unmount /dev/hdc4
swapon /empeg:/empeg/bin# ro
empeg:/empeg/bin# unmount /dev/hda4
bash: unmount: command not found
empeg:/empeg/bin# unmount /dev/hdc4
empeg:/empeg/bin# q
bash: q: command not found
um^Hnempeg:/empeg/bin# q
empeg:/empeg/bin#
What am I doing wrong?
Dave
MK2 12Gb
MK2a 60Gb
#209860 - 19/03/2004 07:25 Re: Question about V3.0 alpha7 [Re: DBALKUNJR]
pupvogel
Loc: Hamburg, Germany
Hi there,
seems like you always entered 'unmount' instead of 'umount' ... !
Just do it like it's in the FAQ:
ro
umount /dev/hda4
umount /dev/hdc4
swapon /swapfile
fsck -fay /
fsck -fay /dev/hda4
fsck -fay /dev/hdc4
swapoff /swapfile
sync
...and you should always wait for the shell-prompt to reappear, before entering the next command.
Up there you entered rwm and didn't wait for the process to finish before entering the next commands...rwm always takes a while...
Ken
#209861 - 19/03/2004 07:37 Re: Question about V3.0 alpha7 [Re: pupvogel]
DBALKUNJR
OK, I am seeing things this morning...(Lack of Coffee). So I entered as shown below and get this after I enter fsck -fay:
empeg:/empeg/bin# umount /dev/hda4
empeg:/empeg/bin# umount /dev/hdc4
empeg:/empeg/bin# swapon /swapfile
Adding Swap: 16596k swap-space (priority -1)
empeg:/empeg/bin# fsck -fay /
Parallelizing fsck version 1.19 (13-Jul-2000)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
hda5 is mounted.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/hda5: 1512/4096 files (0.5% non-contiguous), 9996/16384 blocks
empeg:/empeg/bin# fsck -fay /dev/hda4
hda4 is mounted.
As of now after about five minutes there is still no shell prompt after the last line I entered. Is this the way it is supposed to be?
Dave
MK2 12Gb
MK2a 60Gb
#209862 - 19/03/2004 07:41 Re: Question about V3.0 alpha7 [Re: DBALKUNJR]
Yes. It is now doing the music partition on the first hard drive. Depending on the hard drive capacity and how much music you have on it, it can range from a few minutes to almost an hour (for really full 80GB drives).
#209863 - 19/03/2004 20:46 Re: Question about V3.0 alpha7 [Re: pgrzelak]
DBALKUNJR
Just wanted to pass on a word of thanks to all of you for your great help....as usual. Help like this though seems like the status quo around this BBS It is really refreshing. Cheers!!
Dave
MK2 12Gb
MK2a 60Gb
