OK, I am hooked up in Hyperterminal and it seems that it won't accept my input. I get the EXT2-fs warning and when I try to follow the commands from the FAQ on how to rectify it I get this:
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v378 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Sat Feb 21 18:05:39 EST 2004
empeg-car player (hardware revision 9, serial number 10101980)
Command line: mem=16m
Memory: 15016k/16M available (980k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005480).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-230, ATA DISK drive
hdb: IBM-DJSA-230, ATA DISK drive
hda: IBM-DJSA-230, 28615MB w/1874kB Cache, CHS=58140/16/63
hdb: IBM-DJSA-230, 28615MB w/1874kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:07:b
c
Partition check:
Timezone: /usr/share/zoneinfo
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
Timezone: /usr/share/zoneinfo/Atlantic/South_Georgia
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
player.cpp : 564:empeg-car 3.00-alpha7 2004/02/13.
! tags.cpp : 61:Failed to open tags (0xc0041002).
Prolux 4 empeg car - 2.1490 Feb 13 2004
Vcb: 0x4082c000
Restored terminal settings
Player exited normally: 0
Starting bash.
empeg:/empeg/bin# rwm
EXT2-fs warning: mounting unchecked fs, running e2fsck is recommended
ro
unmount /dev/hda4
unmount /dev/hdc4
swapon /empeg:/empeg/bin# ro
empeg:/empeg/bin# unmount /dev/hda4
bash: unmount: command not found
empeg:/empeg/bin# unmount /dev/hdc4
empeg:/empeg/bin# q
bash: q: command not found
um^Hnempeg:/empeg/bin# q
empeg:/empeg/bin#
What am I doing wrong?
Dave
MK2 12Gb
MK2a 60Gb
