I looked around, and couldn't really find any details on how the emplode software works. Sure would be nice to see an example of it in operation. :)Okay, Kureg, here's the relevant information from the e-mail I sent to Doug. Basically, Doug's planning on getting a Mark 2 and, like you, was curious about how the software and the playlists worked. Since I already own a Mark 1, I was answering his questions. So here it is:
>As I understand it, I can establish primary indices (i.e.,
>"playlists") based on a limited number of variables -- probably
>things like artist; title; album; year; genre; and no doubt a few
>more, including some that I can define for myself.
Nah, not really. The playlists are completely freeform, they are not dependent upon any variables. They're a lot like creating folders in Windows Explorer. All you really do is name them, and you can name them anything you want, and put any songs you want into them.
Now, it just so happens that I have playlists that are organized by album and artist, but that's just because I named them that way, not because of any inherent variables.
The variables you listed (artist title album year genre) are the only variables attached to the songs, there aren't any more (well, there's a comment field but it's not used by the Empeg). They are part of the MP3 file format. You can't (at the current time) define your own variables.
Note that you can perform
searches on those variables, but that's a different function than the playlists.
>There appears to be no limit to the number of separate
>playlists I can establish. So I could have, say, ten songs
>distributed in three playlists: (...)
Yes, your description of how you can mix and match songs in different playlists is fairly accurate. Personally, I don't make mine that complicated, but you certainly can if you like.
>Above (and containing) those nine playlists, would be a
>playlist called Classical. On the same level might be
>other playlists for other genres, like Rock, Jazz, Country,
>Reggae, Rap, and Blues.
Yes, you could do that. But it doesn't have to be arranged by genre. The structure is totally arbitrary. For instance, in Chip's video, he had one called "80's stuff". The playlist wasn't created on a "year" variable, he just named a playlist "80's stuff" and dragged his favorite 80's songs into it.
>Above those seven might be two playlists defined as Vocal
>and Instrumental.
You could organize the tree that way, yes, but then you'd probably be making the navigation too "deep" to be useful. How you organize the playlists is up to you, but I'd recommend against going more than a couple levels in depth.
>Above that might be root.
Right, and the "root" represents everything on the unit. Notice how on Chip's video it has that little "triangle"? That's the play button for that "level". If you hit "enter" on that triangle at the root level, it plays every song on the unit. If you scroll left or right to another playlist and hit "enter" on that playlist name, you'll be given another menu of the songs and the sub-playlists in that group. It will also have a "play" button, where hitting "enter" there would play that section of the playlist tree. And so on down the tree.
As you can see, if you make your playlists too complicated, it would become difficult to navigate.
>subcategories that can be defined under each division.
Right. The only limit is your tolerance for navigating sub-trees while driving. :-)
>The real art will be defining and setting up the
>playlists. I think it will be very important not
>to be in a hurry here. "Measure twice, cut once" type
>of mentality will be required.
Not really. It's so brain-dead easy to reorganize the playlists that you can set them up any way you want and change them later to suit your tastes.
It's really not as difficult as you think, and doesn't require as much forethought as you're giving it. I was a little concerned about it when I was waiting for my Empeg to arrive, and when actually got it, I saw that I was worrying for nothing.
>What I don't understand is how I make the playlists -- the actual
>physical button pushes required.
Ah. It's real easy. I'll describe it...
(Refer to the attached screen shot file for reference.)
When you run the Emplode program, the first thing it does is polls the USB port for the Empeg and downloads the playlists that are currently on it. Emplode won't work unless the Empeg is plugged in. All playlist info is stored ONLY on the Empeg itself.
Once it's downloaded the playlists from the Empeg (takes about five seconds), it displays the playlists in a windows-explorer-like interface. There is a tree-list on the left pane, with all the playlists shown hierarchically. Once you double-click on a playlist, the right pane displays the songs and/or sub-playlists.
Creating a playlist is a lot like creating directories in Windows. First, you select the parent location where you want the playlist to go. For instance, if I were going to put my remastered copy of Permanent Waves on the Empeg, I might start by selecting my "Rush" playlist. Then you hit Edit/New Playlist on the menu. A box appears allowing you to enter the name for the new playlist. For instance, I might enter "Permanent Waves (Remaster)" in the box. Press Enter, and the playlist is now ready to drop tunes onto it.
To add new tunes to the playlist, you drag and drop them from Windows onto the playlist in Emplode. To copy tunes from another location in the Empeg, you drag and drop the same way, you just do it within the Emplode program. You can also use the cut/copy/paste commands inside Emplode if you're not good with dragging and dropping.
>Then, how are the playlists transferred to the empeg?
Playlists, edits to playlists, and songs are all transferred with one command- the "Synchronize" command. It's on the File menu, or, referring to the screenshot, it's the little red arrow button on the left end of the toolbar.
Any changes you made in Emplode (whether they be additions, deletions, changes, etc.) get reconciled when you hit that button. Since beta 10, it's even STABLE and actually WORKS. :-)
>Suppose that I want to take a song out of the String Quartet
>playlist, and make a new playlist called Chamber Music and put
>that song (and several others) there instead? Do I keep my
>"master" playlist on my Windows machine, keep it updated there,
>make the changes there, and then when the whim hits me do I use
>emplode to replace the whole playlist structure in the empeg?
As you may already have gleaned, you do not maintain a master playlist on the Windows hard disk. Emplode is just a dumb terminal, reporting and editing the playlist structures stored directly inside the Empeg unit itself. This has the advantage of allowing you to edit the Empeg at any computer. I perform edits both at work and at home, and I don't need to worry about keeping the playlist structures synchronized between the two machines because there's nothing to synchronize- it's all stored on the Empeg.
Okay, on to your specific example:
The first step would be to create the new "Chamber Music" playlist. Then you would select the "String Quartet" playlist and scroll the right-hand window pane so that you can see the song within that playlist. Then, scroll the left-hand window pane so that you can see the new "Chamber Music" playlist in the tree.
Then simply drag and drop the song onto the "String Quartet" playlist.
By default, it will MOVE the song from one playlist to another. If you want to COPY the song instead (so that it ends up in both playlists), you hold down the Ctrl key while doing it.
See? It's just like Windows Explorer.
>suppose I want to listen to Mozart Concertos. I don't have a
>playlist defined for that. I have a Mozart playlist defined. I
>have a Concerto playlist defined. But not a Mozart + Concerto
>playlist. Is there a way to create such a playlist on the fly
>within the empeg?
No, there isn't. The only way to create playlists is with Emplode. But you could just hit your Mozart playlist and press the >> button every time a non-concerto comes up. :-)
Tony FabrisEmpeg #144
