Beta has been working just fine until today when I finally set the time through the GUI.
The power was cycled and it hung with starting audio on the display.
I flashed it again with both the consumer and developer versions to no effect.
Here is the log on the serial port of the boot.
Incidentally, I've tried this with both the ethernet cable plugged in (office LAN with DHCP) and without the ethernet cable plugged in. This report showing without it plugged in.
It does obtain an IP address when it is plugged in to the LAN.
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.14-rmk5-np17-empeg49 (mac@aphex.internal.empeg.com) (gcc version 2.95.3 20010315 (release)) #127 Wed Oct 17 16:02:35 BST 2001
empeg-car player (hardware revision 7, serial number 90000822)
Command line: mem=12m
Memory: 10968k/12M available (964k code, 20k reserved, 332k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
Could not find CS4231A (version=80)
empeg state support initialised 0089/88c1 (save to d0004f80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DARA-212000, ATA DISK drive
hdb: IBM-DARA-212000, ATA DISK drive
hda: IBM-DARA-212000, 11513MB w/418kB Cache, CHS=23392/16/63
hdb: IBM-DARA-212000, 11513MB w/418kB Cache, CHS=23392/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:12:03:36
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump... VFS: Mounted root (ext2 filesystem) readonly.
change_root: old root has d_count Trying to unmount old root ... okay
Freeing unused kernel memory: 4k initI see this is a developer image!
Mounting proc
Starting player
empeg-car 2.00-beta3 2001/10/17.
00000008 DHCP name = lo
00000008 DHCP index = 1
00000008 DHCP flags = 0x8
00000008 DHCP addr = 0.0.0.0
00000008 DHCP bcast = 0.0.0.0
00000008 DHCP mask = 0.0.0.0
00000008 DHCP name = eth0
00000008 DHCP index = 2
00000008 DHCP flags = 0x1002
00000008 DHCP Our mac is 00:02:d7:12:03:36
00000008 DHCP Current IP address is 0.0.0.0
00000008 DHCP Broadcast address is 0.0.0.0
00000008 DHCP Attempting to open Autonet socket for eth0
00000008 DHCP Adding interface eth0
00000008 DHCP Sending DHCP discover (eth0)
000
