#43293 - 22/10/2001 17:19 Boot Hangs at starting audio on dsiplay
bmiller
Loc: Sacramento, CA, USA
Beta has been working just fine until today when I finally set the time through the GUI.
The power was cycled and it hung with starting audio on the display.
I flashed it again with both the consumer and developer versions to no effect.
Here is the log on the serial port of the boot.
Incidentally, I've tried this with both the ethernet cable plugged in (office LAN with DHCP) and without the ethernet cable plugged in. This report showing without it plugged in.
It does obtain an IP address when it is plugged in to the LAN.
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.14-rmk5-np17-empeg49 (mac@aphex.internal.empeg.com) (gcc version 2.95.3 20010315 (release)) #127 Wed Oct 17 16:02:35 BST 2001
empeg-car player (hardware revision 7, serial number 90000822)
Command line: mem=12m
Memory: 10968k/12M available (964k code, 20k reserved, 332k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
Could not find CS4231A (version=80)
empeg state support initialised 0089/88c1 (save to d0004f80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DARA-212000, ATA DISK drive
hdb: IBM-DARA-212000, ATA DISK drive
hda: IBM-DARA-212000, 11513MB w/418kB Cache, CHS=23392/16/63
hdb: IBM-DARA-212000, 11513MB w/418kB Cache, CHS=23392/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:12:03:36
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump... VFS: Mounted root (ext2 filesystem) readonly.
change_root: old root has d_count Trying to unmount old root ... okay
Freeing unused kernel memory: 4k initI see this is a developer image!
Mounting proc
Starting player
empeg-car 2.00-beta3 2001/10/17.
00000008 DHCP name = lo
00000008 DHCP index = 1
00000008 DHCP flags = 0x8
00000008 DHCP addr = 0.0.0.0
00000008 DHCP bcast = 0.0.0.0
00000008 DHCP mask = 0.0.0.0
00000008 DHCP name = eth0
00000008 DHCP index = 2
00000008 DHCP flags = 0x1002
00000008 DHCP Our mac is 00:02:d7:12:03:36
00000008 DHCP Current IP address is 0.0.0.0
00000008 DHCP Broadcast address is 0.0.0.0
00000008 DHCP Attempting to open Autonet socket for eth0
00000008 DHCP Adding interface eth0
00000008 DHCP Sending DHCP discover (eth0)
000
#43294 - 24/10/2001 04:13 Re: Boot Hangs at starting audio on dsiplay [Re: bmiller]
That isn't a complete log.. perhaps the last bit was not flushed to the logfile when you pasted?
#43295 - 24/10/2001 08:17 Re: Boot Hangs at starting audio on dsiplay [Re: rob]
edwin
Loc: Druten, The Netherlands
from his bootlog: Could not find CS4231A
This is bad! It's AUX-IN.
ญญ______________
Edwin de Vaan
[white]ญญ______________[/white]
Edwin de Vaan aka FLaSHmAStER
#43296 - 24/10/2001 09:16 Re: Boot Hangs at starting audio on dsiplay [Re: rob]
bmiller
No, that's all i was getting.
Last night I did get it working incidentally. It looked like the CPU was getting pegged because eventually I was able to get the keys on the front panel working for some reason but the GUI was very very slow...
The source was for some reason set to AUX of which i have nothing connected. I was able to navigate the GUI and switch the source back to player and then everything was fine. The player became operational and was runnning at normal speeds.
I'm wondering if this has something to do wth polling the AUX-IN for track identification and running the visuals. Since there was nothingm it choked.
Also, I'm finding that my clock does not keep the time set. It has defaulted back to 12:00 July "something" 2001 several times.
#43297 - 24/10/2001 12:31 Re: Boot Hangs at starting audio on dsiplay [Re: bmiller]
edwin
#43298 - 24/10/2001 12:40 Re: Boot Hangs at starting audio on dsiplay [Re: edwin]
bmiller
Does that mean that you think it's hardware?
#43299 - 24/10/2001 12:44 Re: Boot Hangs at starting audio on dsiplay [Re: bmiller]
edwin
Sorry for my very cryptic answer, I'll try not to do that anymore...
The fact that the bootlog shows the chip can't be found is a hardware related issue if you ask me. I recommend contacting support@empeg.com for sorting this out.
ญญ______________
Edwin de Vaan
#43300 - 24/10/2001 12:47 Re: Boot Hangs at starting audio on dsiplay [Re: edwin]
bmiller
I haven't tried using AUX port for some time now. Probably a few months.
I can't see the need for it in the forseable future and as long as I keep it in player mode it works.
Other than the fact that it'd be great to keep it in tip-top shape, do you think it's a necessary repair? I'll have to check if I'm inside the terms of my warranty. I added a second hard drive so they may void it.
The player is working fine now, just only when in player mode.
#43301 - 24/10/2001 13:07 Re: Boot Hangs at starting audio on dsiplay [Re: bmiller]
edwin
You might have read about the problem I had concerning AUX-IN a while ago. The cause for this problem wasn't entirely related to the chip (CS 4231A). So other things might have had some influence. I'm not telling you that you must have your unit repaired, but I just recommend having it repaired if it's still in warranty, which is one year from the date of purchase. Basically: if I was you, I would have it repaired!
ญญ______________
Edwin de Vaan
#43302 - 24/10/2001 13:15 Re: Boot Hangs at starting audio on dsiplay [Re: edwin]
bmiller
I'm still waiting to receive the wiring loom from support so I can get my tuner working. I've had it for some time now and I have never seen it work yet.
I wouldn't mind having some confirmation from someone at empeg who frequents the BBS that this would be the correct action considering the facts I've presented. I don't want to bring up another issue until the first one is resolved, especially if they're just going to tell me that I'm out of warranty or something.
Sending my whole unit and tuner in is what support recommended when I emailed them about my tuner not working. Thanks to Q/A on the BBS, I didn't have to, they just sent me a new loom. Now, it just has to get to me.
