Doh, you're definitely correct on that one. I put that very poorly. Hrm... Okay... am i correct in that the blanking function is meant to be a screen saver in the truest sense? If so... then if there are visuals on the screen moving about, or something scrolling, then there is no reason to blank the screen to prevent burn in. If however there is a static image on screen, then there is a need to blank the screen.
I use the current blanking setup and would like it to stay the way it is...
If i put on a playlist and am sitting at my machine, then i want the screen on flashing and scrolling about. . . but if I jump up to go review an animation or something and leave my desk without turning the empeg off and the playlist ends and i don't return for another hour or so, i don't want it sitting there with a static screen. That just makes sense to me. I don't see what the point of the other way is... if you don't want the screen on then set the visual to off.
Am i alone in seeing it that way?
