Zelda has a setup screen with a row of boxes (three I think). When those boxes are all square, your screen is set up properly, either in 4:3 or widescreen, depending on your configuration.
You could also just go into the setup screen and make sure you selected 16:9
True, but the boxes did remind me to hit the widescreen button on the remote - it was on full instead of normal or vice/versa and kept it at 4:3 even though the signal was at 16:9
