I got the board... nice work!
Now, could someone who has it installed and working post photos of the install? I'd really appreciate it!
Here's the instructions I have from Ben so far:
V+ is +12
GND is Ground.
Fan + and Fan - are the plus/minus leads from the fan. (12v Fan, of course)
SDA and SCL are the "Serial Clock" and "Serial Data" lines from the processor.
I have a photo of the 2 points in my Projects section... the second to last is
"dark" with highlight areas around the resistors, but it s doesn's say which is
SCL and which is SDA;
SDA can be found on the RIGHT HAND END of the resistor marked 1003 nearest
the top left corner of the strongarm (display board towards you).
SCL can be found on the TOP END of the resistor marked 1003 directly to the
right of the centre mounting hole.
