Hey loren,
Did you get your fan to work?
did you see Benjamin's pictures? it looks like he is using a connector to the pcb board instead of soldering each wire to the board like you did.
How will you mount the board?
How did you solder to the scl and sda on the empeg board? is it okay to just solder at either end of each?
thanks.
