It's definitely my skin touching the metal case in a certain spot (lower left side) that is causing the issue. I used a single post it note to sit between my skin and the phone, and had full signal strength again.
Thats where the WiFi antenna meets the cellular antenna. What happens if you turn off WiFi and touch that point?
