Originally Posted By: taym
Did I understand correctly that you do not see any record of the following reboot either?!?
The boot (I had to manually power the computer on) is fully logged. At this time I can say with some confidence that the shutdown or crash (that also shut down the machine) is related to the version of SlimCenter I had installed. I will try to confirm that by reinstalling it on Friday (when I don't need to make any recordings).
[quote]
Out of curiosity, "disabled" Windows Updates means it does not update automatically and you do so manually, or simply it does not update at all?
It was fully updated when I reinstalled Windows sometime earlier last year. Since then no updates have been applied and that's the way it's going to stay. This machine is not used for email, web browsing or any other active internet connectivity. Firewall is enabled and no ports are forwarded to it from my router. The only software that gets installed on it are manual updates for SageTV and SlimCenter.
